prince loader valve HC-V-BP22
/ prince loader valve HC-V-BP22 #1
gav64
Bronze Member
Eastern Connecticut
Mahindra 2810hst - Gehl 4625 skidsteer
Has anyone used/installed one of these valves, I need to replace my loader valve and saw this on surplus center website.
I would like to add a 3rd function for a snowplow this winter was going to use electric solenoid valve but this looks a whole lot easier.
3 SPOOL 25 GPM JOYSTICK LOADER VALVE W/GRAPPLE
Glenn
/ prince loader valve HC-V-BP22 #2
Logically, you want to match the flow rate of your tractor with the loader valve selected.
Mahindra 2810hst
Hydraulics:
Type: open center
Gear Pump flow: 5.88 gpm [22.3 lpm]
Hydro Pump flow: 6.3 gpm [23.8 lpm]
Gear Steering flow: 3.07 gpm [11.6 lpm]
Hydro Steering flow: 4.55 gpm [17.2 lpm]
If your tractor flow rate is about half the loader valve, at half lever, you will be flowing total pump flow.
You could get this loader valve and still get a diverter or a 3rd function valve.
2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
Diverter valve from Baileynet for about $110.
3rd function valve from Surplus solenoid OC valve
12 VDC 10 GPM OC DA SOLENOID VALVE
1 STATION DO3 SUBPLATE OPEN CENTER
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
2012 FORD F-450 FLAT BED SUPER DUTY (INOPERABLE) (A60736)
2012 FORD F-450...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
