Priming oil pump?
   / Priming oil pump? #1
Poorboy04
Rixeyville Virginia
new holland TC24D
I just purchased a remanufactured shibaura engine (N843L TC35). It says I need to prime the oil pump before starting the motor. I know you fill up the oil filter with oil but I'm positive there are other things I need to do. Can anyone walk me step by step what else I need to do.
   / Priming oil pump? #2
Pull all the glow plugs so the engine rotates freely then crank it over a bit until you have oil pressure showing on a gauge, usually a 0-30 psi gauge you can put where the oil pressure switch is if it has one.
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
