Priming bulb, fuel lines, ethanol
   / Priming bulb, fuel lines, ethanol #1
elmerinva
eastern virginia
B2100
Since they've been adding ethanol to gasoline, all my two-stroke fuel lines and priming bulbs have gotten hard and cracked, requiring replacement. Anyone else having these kinds of problems? The priming bulb is expecially hard to replace--no one seems to have this part for my old, old engines--Homelite blower for example.
   / Priming bulb, fuel lines, ethanol #2
I just had to replace the fuel lines and primer bulb on my Homelite string trimmer. I found the replacement bulb at a local small engine repair shop.
Vic
   / Priming bulb, fuel lines, ethanol #3
Lowe's has primer bulbs. Saw them the other day . In the parts area. (Blades, belts)
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
30058 (A53424)
30058 (A53424)
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
