PRIME PRE-FILTER MF 1840
   / PRIME PRE-FILTER MF 1840 #11
It sounds like the 19mm bolt you opened is similar to what I was referring to as the vents on the top of my housings. In my case I have to use the plunger to push diesel into the housings to bleed the air out. However, in your case once you opened your "vent" gravity was able to purge the air from your filters.
Glad you were able to figure it out and thanks for posting your solution so that others will know.
You were correct in pointing me in that direction. To be clear, on my tractor, I need to turn on the key so the fuel pump is on but not turn on the starter motor or ignition. The electric fuel pump is located between the 2 filters and pulls and pushes the fuel through both filters.
   / PRIME PRE-FILTER MF 1840 #13
If it has an electric fuel pump, usually there is no bleeding like old school necessary. Just turn the key on and let it sit for two minutes.
That's why your manual doesn't state anything specific.
The same with JD. That's the nature of common rail fuel systems.
2014 Ram 1500 EXPRESS (A50323)
2014 Ram 1500...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52128)
NEW 2022 Load...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
2016 KUBOTA RTV-X900 UTV (A51242)
2016 KUBOTA...
