Pricing out an L6060
/ Pricing out an L6060 #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
I visited Lano Equipment today to look at and listen to the L6060.
Priced out with a 1055 loader, an HD 72" bucket with a replaceable bar, swivel air seat, 3 spool valves, draft control, mid PTO, 3rd function, all the lights, top and tilt kit, and maybe something I'm forgetting about came in at $51,200ish before tax.
I'm comparing the Kubota with Deere's 4066R and Massey's MF1758 and I made a video after driving the tractor around a bit flipping forward and back and turning.
/ Pricing out an L6060 #2
What's your plan with the tractors your looking at? For about the same money you could get twice the tractor. I was really hung on getting a hydro till I ran power shifter.
/ Pricing out an L6060 #3
That's what I was thinking. That's a lot of $$ for a 60hp ta tractor. If I was spending that kind of money I'd be looking at an M series tractor without question.
I plan to use it to selectively clear and subdivide 2900 feet of lakeshore property and build a little under 1 mile of road and grade in preparation for foundations. I will be using a HD bucket, root grapple, top and tilt, box blade, most likely a 6' Woods BB6000X rotary cutter, a snow plow mounted on the loader, and a 3PT blower. From what I've seen and learned, if I thought I wouldn't burn out the clutches in a sync-shuttle, a used 2012 or new Deere cab on 5083 would be a bargain. As it is, I cannot afford a larger CVT tractor and the little 50hp CVT from Case I believe to be too small for my needs.
I also hope to pick up some for hire work with it as well.
That all said, what are you thinking?
/ Pricing out an L6060 #5
You're saying that you think you'll burn out clutches on a power-shuttle? I really doubt you'll have a problem with that, and even if you have to do the clutch, you'd still save money versus the L.
/ Pricing out an L6060 #6
I plan to use it to selectively clear and subdivide 2900 feet of lakeshore property and build a little under 1 mile of road and grade in preparation of foundations. I will be using a HD bucket, root grapple, top and tilt, box blade, most likely a 6' Woods BB6000X rotary cutter, a snow plow mounted on the loader, and a 3PT blower. From what I've seen and learned, if I thought I wouldn't burn out the clutches in a sync-shuttle, a used 2012 or new Deere cab on 5083 would be a bargain. As it is, I cannot afford a larger CVT tractor and the little 50hp CVT from Case I believe to be too small for my needs.
Stepping into the next larger series of tractors with power shuttle(power reverser) will do any of that work with no problems. Your utility tractors are going to put up with much more wear and tear then any of the hydro trans. Pulling, pushing, ground engaging are far superior on the larger machines. The draw back are their size and weight. The next series tractors will also have twice to three times the lift power for FEL work.
One Massey dealer did suggest I look at their 4600 machine, their smaller framed utility tractor. Trouble is that machine is 5k more and that is before piling on options.
I mean guys, these things are all expensive. My best price on a 4066R set up like the Kubota quote is $52K plus tax. The Massey MF1758 without tax is $45500.
/ Pricing out an L6060 #9
For the $$$$ that you are looking at, you really need to look at the next larger (utility size machine) Waaaaaaay more machine for about the same money.;)
calhoun9001, I get it. I can get a bigger tractor for about the same amount of money and for the life of me, I don't know why the compact tractors are so much money. I've found the 83E at tractorhouse with loaders for less than $40K and they have a shedload more power. My application is selective clearing on slopes while winding around the "keeper" trees (people buy lake homes in Minnesota for the location, lakes and the trees and then they look at the home in that order). My thinking is that at some point the tractor starts to get too big.
Transmission wise, I watched a nice survey via demo of different tractor transmissions and I thought the hydros where the way to go with how much forward and back I'd need to do.
That said, I'd making an pilgrimage down to Iowa to look at the gear version of the MF1758, a MF1759 which is every bit as expensive as the 1758. :confused3:
/ Pricing out an L6060 #11
If your going to be in tight situations most of the time, I would agree that your looking at the right tractors. I ran a 4320 to do most of my work when I built a home on a couple acres, was a great tractor. A bigger tractor was never needed. I loved the hydro trans for that application. If your going to stay with CUT I would definitely get the hydro trans.
/ Pricing out an L6060 #12
ThL6060 is quite light for much of a root grapple.
Why do you need/want draft control. For your plans you do not need it and cannot effectively use it with R4 tires.
Hydrostats are very convenient but also very inefficient. For your purposes (unless you plan to use your tractor mostly for variable speed/reversing work) I would look for a larger frame size tractor with a hydraulic reverser. The MF 4600 series might be a good choice and the incentives are currently good.
SDT
/ Pricing out an L6060 #13
Owning an L5740HSTC and an M8540HDC, I can certainly understand both sides of the coin. I often run both in a single day and bought the L5740 after the M8540 for the tight, close in work that will wear you out on an M or the M simply won't fit. I love the M Series Kubota and really like the equivalent in JD, Massey etc., but there are times a CUT like the L5740/6060 is just the right tool.
I wouldn't/don't worry about burning out the hydraulic clutch on our M Series and we use it for a lot of back and forth loader work and box scraper in addition to running a 10' pull type rotary cutter, they are very good systems; same goes for the other makes.
I am slower than my sons doing loader work with the M8540, but they will usually grab the L5740. They can operate both about as quickly, but are much more tired at the end of the day on the M.
Yes, the M is a stronger, more robust machine, will lift and pull more, but for our uses, there will always be a need for the 5740. Cost is high, but the HST+ is worth it for us at least and I noticed the new John Deere CUTs have an eHydro with some of the same features.
I can't honestly say which is best for the OP, only relay our experience.
/ Pricing out an L6060 #14
Hydro transmissions are very slick to operate, and very convenient. They are less efficient than gears, but many of us feel they are worth it.
That said, for what you want, you should at least test drive a power shuttle transmission. You can get a bigger stronger tractor for less money.
As far as fitting in smaller spaces, the narrowest wheel spacing on the bigger tractors should still be pretty small.
I had another thought also, for your budget you could buy two tractors. How about a mx5100, a large open station hydro tractor, and a cabbed b or bx. Unless air conditioning is a major reason you like a cab, you can get by without it during the summer. An open station will be better in the woods too. Just something to think about. Or maybe a tractor and a used skid steer. Two machines would be more versatile that one. I just think that of all the people I've heard wanting to complete the type of projects you want to do, I don't hear too many people buying 6060s, 5740s, or similar tractors. You should be able to get more capability out if your budget.
Of course if the 6060 is what you want, and the features are worth the $$ to you, go right ahead. I bet that's a sweet tractor to own, good luck.
/ Pricing out an L6060 #15
I am adding a grapple right now along with 400 pound wheel weights to go with the filled tires as we work on a lot of hills, my counter ballast is a Land Pride HR3584 at a bit over 1100 pounds.
I didn't get draft control, but at times kind of wish I had.
I took my pilgrimage to Iowa today and looked at both a MF4609 and a MF1759. Along the way I visited a Deere 5085E as well. Although in my mind I entertained utility tractors as options, in person both the MF4609 and 5085E are way too big for what I want to do except for road building. I did not make a video for either the 5085E or MF4609 because I didn't think I knew enough about them and because I'm discussing the merits of the L6060 and MF1700s (and Deere's 4066R if they build one before I purchase). The MF1759 is ruled out because I decided that the hydrostatic is easier to use. I'm waiting for a sharper quote on the 1758 to come in my email to compare with the quote on the L6060. In the meantime, here are my initial impressions of the MF1759
/ Pricing out an L6060 #17
I took my pilgrimage to Iowa today and looked at both a MF4609 and a MF1759. Along the way I visited an Deere 5085E as well. Although in my mind I entertained utility tractors as options, in person both the MF4609 and 5085E are way too big for what I want to do except for road building. I did not make a video for either the 5085E or MF4609 because I didn't think I knew enough about them and because I'm discussing the merits of the L6060 and MF1700s (and Deere's 4066R if they build one before I purchase). The MF1759 is ruled out because I decided that the hydrostatic is easier to use. I'm waiting for a sharper quote on the 1758 to come in my email to compare with the quote on the L6060. In the meantime, here are my initial impressions of the MF1759 YouTube Link: http://www.youtube.com/watch?v=yVjE5xxcLwc
One comment on your video - you state the Massey has a stronger rear axle due to planetaries rather than bull gear reduction but the specs I find on the 1758 say bull gear final drives. I'm not saying that is bad. Bull gears end up being larger to transmit the same power at the same gear reduction but they do have advantages. Goodness knows I have had enough failed planetary parts around my home until my wife made me scrap them because she considers them junk rather than works of art.
I admit to having brain fade. We have added 3 tractors since I retired and haven't considered Massey due to dealer location. Then it dawned on me I get a 10% employee discount after negotiating my best deal with a dealer. I still feel good that my Kubota orange matches my Allis-Chalmers roots from the first 22 years of my engineering career.
Yes, the L6060 and MF1748 (both eHST machines) both use a bull gear final driver rear axle. The 1759 I drove is a sycro shuttle and uses a beefier planetary final drive.
The 1759 has the identical engine spec as the 1758, but due to the HST, the 1758 has a lower PTO output than the 1759 (high 44-point-something versus 47). Assuming all specs are true and use the same method of measurement, the L6060 has better than 10% more PTO power (45ish versus 52ish). The Massey engine is smaller than Kubota's engine. In my videos you can see the Massey idles around 900 rpm compared to Kubota's 6-700 rpm. Yet the Massey weighs more. For me and my special back issues, the Kubota's seat sucked but the seat was not the optional air seat. Also, I felt that I could more easily look backward in the Kubota than the Massey.
Of importance to me, the tie rods on the Massey steering are mounted behind the axle, and much better protected against bashing damage.
Oddly, the MF1759 did not have an air seat, a feature I thought was standard with the cab. The dealer is calling to find out why he could not spec an air cushion seat when he tried to quote me an MF1758.
/ Pricing out an L6060 #19
SDT
The right size root grapple for the capacities of the tractor make it so a root grapple does work! The root grapple does have to be the right size for the tractor and loader and they work great! To have the wrong size or one to heavy will cause problems.
Draft control works with any tires you choose there is nothing that will change the ability of draft control to do it's job with a difference of tires!
The hydro would be the best tractor for his work after the excavating job is done. So why not buy a tractor that would be right for the work you have to do for the majority of the work you have to do?
/ Pricing out an L6060 #20
Sorry, but draft control is needed for tillage work where R4 tires are poorly suited. Hence the modifier "effectively."
Of course grapples, like all other implements, should be sized to the tractor upon which they will be used. Hence the modifiey "much."
SDT
