Pricey Kubota filters
   / Pricey Kubota filters #1
fernbank_bound
Kubota L3010
I just spent almost $100 on three filters for my L3010 (the transmission filter, hydrolic filter, and engine oil filter). I bought these at my local dealer. Man, that's a bit steep! Are there good non-Kubota filter suppliers (or cheaper places to get Kubota filters - possibly on the internet somewhere)?
   / Pricey Kubota filters #2
I can get all the filters for my L3830 thru NAPA except the hyd. filter. Take in your Kutoba numbers and have them cross reference them, you will be suprised at what you will save.
   / Pricey Kubota filters #3
Try pricing out filters at tractorsmart. They are fairly reasonable and quick shipping.
   / Pricey Kubota filters #4
That is steep. I'm looking at a receipt for my L3710, 1 hydro, 1 trans, 2 engine and 2 fuel filters, $65.66.
My last air filter was under $17.
All Kubota OEM and purchased at my local dealer.
   / Pricey Kubota filters #5
I don’t have any information about the filters but I can tell you it is worth your time to call around. I have two Kubota dealers located about 20 miles from my place in opposite directions. When I priced my 50 hr service I was surprised to find that one dealer wanted over $100 more than the other dealer for the same exact service. In this case it wasn’t parts that cost different but how much time the dealers felt they needed to do the work.
Eric
Good suggestions. I'm glad to hear that they can be had for less then what I paid. I'll shop around next time. Thanks!
   / Pricey Kubota filters #7
web page
Try this . it should go straight to wix filters for your tractor. i use wix on mine and baldwin air filters.
web page
you'll need the oem # to cross ref. at baldwin. they even tell you who sells them .
alot cheaper than kubota and high quality. for example i pay $13 for air filters versus kubotas like $40!!!
Great, I'll check it out.
   / Pricey Kubota filters #9
If anyone finds the right side hydro filter, current model fuel filter or the air filters for a B2710 I'd be interested in knowing. I've checked around and can only find Kubota filters for these and they are pretty expensive. The two air filters alone are over $60.00 and the fuel filter is $11.00, both prices are mail order.
   / Pricey Kubota filters #10
Napa filters are Wix except for the factory originals repackaged. I'd be looking at some other dealers for filters. They did have two versions the factory orginals as well as US built units from Fleet Gaurd that are great filters built to factory origainal specs.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
378630 (A51573)
378630 (A51573)
378661 (A51573)
378661 (A51573)
