Priced a new Kubota L2501 with implements
   / Priced a new Kubota L2501 with implements
Finally pulled the trigger. Decided to go with a Yanmar YT235 with Kodiak rotary cutter and box scraper. The dealer is a friend of mine and I wanted to give him my business.
   / Priced a new Kubota L2501 with implements #53
Testing last post problem.
   / Priced a new Kubota L2501 with implements #54
Nice choice. I hope you get many years of use out of it. Out of curiosity, how does this machine stack up against the L2501- size, weight, lift, price? This machine lacks the DPF/regen, correct?
   / Priced a new Kubota L2501 with implements #55
Nice rig! The Yanmar is a nice tractor and very rugged.
   / Priced a new Kubota L2501 with implements #56
O and you should go with the 25 series box blade. It is a good 100 lbs heavier then the the 15.
So I recommend the 2566 BB
Second your motion.
   / Priced a new Kubota L2501 with implements #57
Thanks all for answering questions on top and tilt, as this is all new stuff to me. The dealer later told me I can manually adjust only the top--not the tilt--using the 3 point hitch that comes with the tractor. From what I'm learning here though, top AND tilt is manually adjustable.
Harry Ferguson invented the Three Point Hitch in bits, between WWI and WWII. Ferguson took out international patents on everything, completed about 1936. Since Ferguson's patents expired in mid-1950s, in increments, the Ferguson Three Point Hitch has become an international tractor standard. No one has invented anything better.
Implement tilt is manually adjusted with a screw mechanism on the right Lifting Rod on every Three Point Hitch.
Dealer must be City Folk.
2014 International WorkStar 7400 Truck INOP, VIN # 1HTWGAAR9EH765325 (A51572)
2014 International...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
20711 (A50323)
20711 (A50323)
