PRICE TO ADD BH AND PUMP
   / PRICE TO ADD BH AND PUMP #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
I'm the one that just bought the used LK3054. I was wondering about 2 things.
1. How much does it cost to add a BH attachment that I see so many 3054 owners have?
2. Can I put one of the newer 10gpm hydraulic pumps for the 3054xs on my older 95 model tractor?
I am curious because of some work I have coming up and I am trying to figure the cost of paying someone else vs. doing myself. I realize it would be cheaper to pay someone else but then again I figure I could just subtract that cost from the price of the new equipment and then I get to keep the equipment /forums/images/graemlins/grin.gif
   / PRICE TO ADD BH AND PUMP #2
I'll have to wait until I get home to check the cost of my Rhino 65 (6.5') BH, but since I bought it as a package the cost might not be meaningful anyway.
You don't have to mess with the built-in pump, you can just add a PTO driven pump. That's what I have on mine from new, and there are some advantages to this set up, in that the BH hydraulics are completely self conatined. Also, I find it has a lot of power without going to a high RPM.
   / PRICE TO ADD BH AND PUMP #3
I purchased a rhino 85 for my ck30 for 5800.
Regards
glen
   / PRICE TO ADD BH AND PUMP #4
Rhino 85 backhoe on a CK30!!! /forums/images/graemlins/crazy.gif Not something I would do. Are you sure its the 85 and not the 75??? 85 is wayyyyy to big for that size tractor!!
   / PRICE TO ADD BH AND PUMP #5
Yep it's a Rhino 85. I called Kioti they said as long as the Backhoe don't cause any damage it will be covered.
glen
   / PRICE TO ADD BH AND PUMP #6
</font><font color="blue" class="small">( Rhino 85 backhoe on a CK30!!! /forums/images/graemlins/crazy.gif Not something I would do. Are you sure its the 85 and not the 75??? 85 is wayyyyy to big for that size tractor!! )</font>
I do have question for you if you don't mind? The 85 is only a hundred pounds more then the 75. Is the breakout force the problem?
Glen
   / PRICE TO ADD BH AND PUMP #7
I believe the problem is the added length of the digger causes more toque when digging at deeper depths or reaching out further. Kind of like a cheater bar on a ratchet. More twisting force. My fear would be the BH breaking something then it not being covered and the customer being up the creek without a paddle.
   / PRICE TO ADD BH AND PUMP #8
Is there something I could do to prevent that?
Thanks for you help
   / PRICE TO ADD BH AND PUMP #9
I would be cautious when digging up stumps or rocks and using the hoe as a pry bar for what you are digging up. The 85 has about 900lbs more digging force than the 75. You will problaby be ok, but it is a risk that I would not want to have taken with a $$$ machine.
   / PRICE TO ADD BH AND PUMP #10
I asked Jon Depratt about the new higher volume pump. He thought it would fit without any problems. If you went that way you could run a BH without the PTO pump.
thx
Jim
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
2022 JOHN DEERE 26G EXCAVATOR (A51242)
2022 JOHN DEERE...
2014 John Deere 544K 2 Wheel Loader (A47384)
2014 John Deere...
John Deere 7000 12 R 30 Planter (A50514)
John Deere 7000 12...
