Forks Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used?
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #21
Google Agri Supply. If you have one in your area they are 149.95. Don't know how much to have them shipped. They have very good service and equipment.
Eddie
What is, their 3 point forks? if so, thats cheap.
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #22
gilbertmsg wrote - "Google Agri Supply. If you have one in your area they are 149.95. Don't know how much to have them shipped. They have very good service and equipment"
I got on agri supply's webpage and looked in every catagory for pallet forks without success. I even used their search engine with negitive findings. $149 sounds to good to be true.
MissouriThunder
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #23
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #24
BJN644,
I don't know how you found it but you're a flippin genius. If there's a Agri supply that's close I could drive there and save on the shipping. I think I'm going to make this purchase. Thanks for doing the research. You're a lot smarter than me when it comes to these computers.
MissouriThunder
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #25
I'm glad to know that my endless hours of net surfing have helped a fellow tractor owner.
Let us know how it works if you get one, I may buy one too.
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #26
D@*N!
I need one of those and I was just in Petersburg, VA Thursday!!
I did notice that it's for a Cat 2 hitch. And they have a smaller one for $130 at the store.
Oh well, I'll have to swing by there next time I go to visit the grandkid near Virginia Beach.
However I did score a good bargain Thursday - a $240 saw package for $50 from Northern tool.
They were discontinuing the saw - $220 marked down to $99, and a managers sale for 50% off anything under $100, plus they threw in an extra chain (worth $20).
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #27
newbury,
good catch on the cat 2. I can't use that model. Just curious, was the one for $130 a cat 1 ? And if so did you catch a model number ?
BJN644,
Don't hold your breath. I called the 800 number a gentleman in N.C. said he didn't have a listing for a category 1 hitch. Looks like Willl's pallet fork is the only one that would work for my tractor.
MissouriThunder
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #28
Wonder if you can just change the pins to cat 1?
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #29
Need one to move 1 ton pallets of wood pellets with my JD3120. FEL won't handle a ton. Thanks, Mike:(
Mike, this may help:
I get my pellets in 1.25 ton pallets (60 bags * 40 lbs). My little Kubota B7610 will pick up just a little less than 1/2 that with the 3PH, and about 1/3 with the FEL.
But, where there is a will, there is a way. I have a utility trailer with a tilt-bed. So, I just run a chain through the pallet , and pull it off the trailer slowly with the tractor. Running the chain thought the pallet allows the tension of the chain the take a little weight off the front of the pallet, making it easy to drag. I do this in driveway (which is paved) in front of my garage. Once it is on the ground, I use a pallet jack to move it into the garage. I got the pallet jack used for $150, and it can lift 5000lbs. Because asphalt is "softer" than concrete under the small wheels of the pallet jack, it is a bit tough to pull, plus I have a little lip to get over to get it in the garage, so I just jack it up with the pallet jack, and gently push it into the garage with the FEL. I unloaded two pallets of pellets this way last weekend. MUCH better than unloading them by the bag. When I pick up a third pallet, I'll probably split the pallet up into three pallets so that I can stack them on the other two with my FEL fork.
   / Price question - how much should a 3 pt hitch pallet fork set uo cost? New - Used? #30
BJN644 wrote - "Wonder if you can just change the pins to cat 1?"
I thought this could not be done. Cat 1 3-pt is for cat 1 attachments only. Am I missing something here ?
MissouriThunder
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A55852)
2006 Ford F-550...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
NEW Woods 6ft Finish Mower (A57024)
NEW Woods 6ft...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
