Price on a decent post-hole digger & 9 inch auger
   / Price on a decent post-hole digger & 9 inch auger #1
crown
Platinum Member
Winchester, VA
Kubota B-7500
I got a couple of quotes today on post hole diggers. Local Deere dealer gave me a price of $825 for a bush hog brand. Kubota dealer gave me a price of $795 for a Woods 1130. What is a good price I don't plan on using it very often, but I don't want to have to borrow or rent.
Crown
   / Price on a decent post-hole digger & 9 inch auger #2
Jeff, those don't sound like bad prices for those brands. They're both good, Rhino also makes a good one, Danuser just might be one of the best, etc. However (and some may disagree), in my opinion, for tractors no larger than yours and mine, and no more than you'll use it, for $500 or so you can buy one from Northern Tool or Tractor Supply Co., or some place like that, that you would probably be just as happy with.
   / Price on a decent post-hole digger & 9 inch auger #3
I agree Bird. If a guy isn't going to use one much those cheaper ones are just as good. I've got one that is about 12 years old that was from F&F. New they are about $400. I've probably dug a couple thousand post holes and not one problem and it was used when I bought it.
   / Price on a decent post-hole digger & 9 inch auger #4
Ever thought about looking for a used one? A couple years ago I saw a used one at a garage sale for $150.00. If you're only going to use it once or twice in several years, used might be the best way to go.
SHF
   / Price on a decent post-hole digger & 9 inch auger #5
Re: Price on a decent post-hole digger & 9 inch au
Used ones at auctions go for $250-300 with auger.. These are the lighter duty diggers. Like cowboydoc said, they work just fine for occassion use if you don't abuse it. Even these have shear bolts for drive-line protection. I have used these for years without problems.
   / Price on a decent post-hole digger & 9 inch auger #6
jeff, this is the kind of digger that i bought, for $500.00, bought it through case IH dealer.
<A target="_blank" HREF=http://www.wcnet.org/~gmi/diggers.htm>http://www.wcnet.org/~gmi/diggers.htm</A>
   / Price on a decent post-hole digger & 9 inch auger #7
I bought a Post Hole Digger and a 9" Auger at Tractor Supply Company - TSC - last July (2001) for $460. I'm perfectly happy with it. It's definitely not "Professional Quality", but for my occasional use I'm not too worried about it. You can but replacement teeth for the auger too....
   / Price on a decent post-hole digger & 9 inch auger #8
I got a Landpride light duty with a 12" for $700. $500 for the digger and $200 for the auger
   / Price on a decent post-hole digger & 9 inch auger #9
Jim, Of the three models on the link witch one, and what size auger were you able to get for $500.00
Richard
   / Price on a decent post-hole digger & 9 inch auger #10
the EM500 with 9" auger
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
Kubota L3200 (A50123)
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
(3) PIVOT TIRES (A51248)
(3) PIVOT TIRES...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
