Price Check Price on a B7610 with loader and Backhoe
   / Price on a B7610 with loader and Backhoe #1
Deere3120
Can someone give a rough price on what a B7610 cost with Loader and backhoe? How good is this for snow removal and moving rocks. Rock weight around 800lbs will this tractor be enough or should I go green
   / Price on a B7610 with loader and Backhoe #2
Should be under 20k pretty easily. A Deere is not going to lift more than a Kubota because its Green. Infact more often than not Deere's lift ratings fall short of most everyone else. Loader performance has never been their strong suit.
If you want to lift an 800lb rock your going to need a loader with a lift capacity of about 1600lbs at the pivot pin, 1200lbs at bucket center, which will give about 800lbs out away from the center where your large rocks will be sitting. Thats probably a bit overkill as you can do much more with a loader when you are not raising the loads to full height. You can probably get by with a B7610, but I'd feel alot more confident with a B7800 which is about $1800 more.
How much and how high can the B7800 with the loader lift? They are not big rock only small rocks that fill up the bucket if you know what I mean. I need to load a small dump truck 3500 size.
   / Price on a B7610 with loader and Backhoe #4
I have a B2910 with a 402 loader. It will lift about 800 lbs. I have loaded a 6' high dumpster with it. Spec's state that it will raise 80" without the bucket. This may be a Little low for a dump truck. The L28-3400HST with LA463 loader will raise to 95.5" without bucket. It will lift just over 1000 lbs.
   / Price on a B7610 with loader and Backhoe #5
I got a price today on a new B7610 w/la352 fel $14,485, woods bh6500 $6,750, r4 filled tires delivery etc. I think it is on the high side.
   / Price on a B7610 with loader and Backhoe #6
</font><font color="blueclass=small">( I got a price today on a new B7610 w/la352 fel $14,485, woods bh6500 $6,750, r4 filled tires delivery etc. I think it is on the high side. )</font>
Yes I feel that is high. I just bought a 7610 Hydro drive with the 352FEL, 60" MMM (the better one with the wheels and I think it is close to $2K), R4 tires (filled) for $14,600. in WV and my dealer is delievering it of couse (great dealer if you are nearby)
   / Price on a B7610 with loader and Backhoe #7
<font color="blue"> Rock weighs around 800lbs , will this tractor be enough or should I go green
<font color="blue">
== <font color="black"> Since you didn't like my other reply let me rephrase it.
Why do you think Green might be stronger or more capable of lifting the rock? </font>
<font color="#666666"> This is all I wanted to know.No need for name calling. </font>
Differnt loader ratings. Green Or should I say JOHN DEERE has high lift ratings on there loaders, But I found out they spec. theres on the high side. (Pivot Point).
   / Price on a B7610 with loader and Backhoe #9
I reread your post and I really think the loader may not be able to lift what you want it to. The tractor is fairly light even with loaded tires and a B.B. on the rear. If you were just lifting the weight low (say a foot or so) I would say you may be able to do it, but to dumb in a truck you may need a bit more. Good luck
Dealer told me to get the L3130. Said it's has great lifting capacity and 8' lift height. He priced it out for me with a Soft heated cab, Backhoe, Loader, R4's(loaded) Mid PTO at $31600.00. Big bucket to 72". Looks like that will be my best option. Thanks to all that helped. /forums/images/graemlins/wink.gif
2018 Ford F-150 (A51039)
2018 Ford F-150...
2007 WESTERN STAR 4900 (A50854)
2007 WESTERN STAR...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
