Price of Gravely Model 8129?
   / Price of Gravely Model 8129? #1
trevorl
Gravely 8129
I have an Gravely Model 8129 four wheel riding tractor with a mowing deck that has been sitting under the back cover of my barn for the past couple years. The wiring needs work and the tires need patching, but we tested it the other day and it turned over (it didn't start, but it didn't have any gas left in the tank).
Around what price range should I be asking for it, assuming someone takes it as-is to fix it up and get it running?
In case it matters, I'm in Asheville, NC.
   / Price of Gravely Model 8129? #2
It sort of depends on condition. Non-running might fetch a couple of hundred. Being under cover might help. When a tractor like that is stored for a long time, there is an certain amount of expense and labor that is required to bring it back into running shape. At a minimum, change the oil in the trans and engine, grease the mower deck, replace the grease in the mower drive, fuel filter, fuel tank drain and refill, and possibly a battery. All in all about 8 hrs of work or so. If the mower is noisy, then new bearings and idlers are usually needed and possibly new mower blades. That could be another 2-6 hours of work. Then there is the reason why it was parked in the first place. Quite often, there is some latent issue that caused it to be parked.
I say put it on graig's list for $450 OBO.
Thanks for the advice.
   / Price of Gravely Model 8129? #4
if you have not sold it yet,, you could also try ebay.com to sell it
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
Galvanized Livestock Wire Gates (4X Gates) (A55218)
Galvanized...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
Polaris Side by Side (A50324)
Polaris Side by...
