Price Check price check for tc18
   / price check for tc18 #1
klint
Bronze Member
hi,im looking at a year 2000 tc18 hydrostst trans,4x4,rear blade,rear scope,single bottom plow the tractor has 655 hours and ag tires and is in good codition.the guy will take $4800.does this seem like a good price?
wll this tractor handle a 5ft rear finish mower and a 4ft brush hog?
i would like to hear some input as far as,is it comfortable,how do they do plowing snow and cutting grass.it will be finish mowing 2.5 acers.thanks
   / price check for tc18 #2
The price seems reasonable if it comes with the attachments. I have almost the same unit 3 years newer with turf tires. The 5' finish mower is no hassle. I have not used a bush hog behind it though. I take care of my 1.7 acres with it, mowing and snow as well. I can use a 5' back blade and a 5' box blade without any problem. I tried using a single plow once with mine and was disappointed. But I was a newbie at setting one up too. Never used the plow since.
how long do you think it would take to mow 2.5 acers?ive had a few other larger tractors 25 & 33 hp they took a little over an hour.hows the platform room?
   / price check for tc18 #4
I've got a Tc18 that I use a 42" Bush hog with. I mow 9 acres with it. On average it takes me about 12-16 hours to mow everything. I'm mowing waist high brush with mine, on some steep hills that I can only mow up and down on. The Tc18 would run a 4' bush hog if your mowing relatively flat areas. I also plow my garden with mine. I have no problem pulling a 12" single bottom plow. Once it is set up correctly it works very well. I use a 6' rear blade to move snow with. I use a 4' box blade and a 6' rake to take care of my 1100' driveway.
As for platform room i'm 6' tall and almost 300lbs. I have plenty of room to move comfortably.
Take a look at my photo gallery to see these attachments.
Solo
   / price check for tc18 #5
With my 1.7 acres, it takes about 3 hours, but I have LOTS and LOTS of obstacles to cut around. And a lot of uneven ground which slows me down.
   / price check for tc18 #6
price seems quite reasonable for a clean machine..
soundguy
HYSTER H60XT FORKLIFT (A52472)
HYSTER H60XT...
STORAGE FEES (A52577)
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
