Pressure washer questions
/ Pressure washer questions #1
DaveNay
Platinum Member
Waterman, DeKalb County, Illinois
John Deere 855 MFWD; Oliver 1850 Gas
Hi guys,
I just finished pressure washing my tractor, and I have a couple of questions.....
While washing, I noticed that besides dirt, I washed away a lot of grease from around moving parts (loader bushings, cylinders, etc). I have hit all of the maintenance grease fittings, and made sure they are lubricated, but is there anything else that needs attention?
Also, can I pressure wash the engine compartment? I would really like to remove the side panels from the engine and wash in there. I got behind the dust grille in front, the the engine itself is pretty nasty.
I also have to give a thanks to JD for a well designed loader...this is the first time I have removed it, and the process is really a piece of cake.
Dave
/ Pressure washer questions #2
Dave
I don't like to use a pressure washer on my tractor. I use simple green and a spray nozzle on a garden hose.
There are differing opinions on how to clean a tractor. /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif
Check out this thread.
Click Here
/ Pressure washer questions #3
Check you owner's manual to see if there is a clutch housing drain so you can get the water out of there and keep the clutch from sticking to the flywheel and rusting. Probably center of the tractor not far back from where the clutch is located. Another good thing to do is to keep the clutch latched in disengage when you're not using it, avoids the same problem. John
</font><font color="blue" class="small">( Check you owner's manual to see if there is a clutch housing drain...)</font>
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
Hydrostatic.
Dave
/ Pressure washer questions #5
Your hydro still has a clutch does it not? I use it when I shift from 4WD or shift ranges. Or do you have an electric PTO and ranges? My CK20HST has a clutch and a drain plug. John
</font><font color="blue" class="small">( Your hydro still has a clutch does it not?)</font>
Nope, no clutch at all. Forward pedal, reverse pedal, high speed/low speed selector and 2wd/4wd selector. The rest is all magic. /forums/images/graemlins/cool.gif
Dave
/ Pressure washer questions #7
"While washing, I noticed that besides dirt, I washed away a lot of grease from around moving parts (loader bushings, cylinders, etc)."
As they say in the Navy, "If it moves grease it, if not paint it." It's best to keep all moving parts greased.
/ Pressure washer questions #8
are u saying that when u want to change ranges, hi , lo or engage/ disengages pto, or switch from 4wd to 2wd you don't have to depress a pedal?
/ Pressure washer questions #9
on the original theme of this post, i never use the pressure washer on the tractor, just use a hose and soap and on the engine area just a good degreaser with rags to keep it clean. do it once or twice a year, and it never gets so bad u need a pressure washer.
/ Pressure washer questions #10
Hi Dave:
Never owned a JD, but pressured washed my 28hp Jinma with no worries....even the engine compartment.
My pressure washer kicked out about 1500 psi, so not very strong compared to some other more powerful units out there.
I'd say go for it, but keep the pressure down.
gbob
p.s. I also used engine degreaser with mine....came out sparklin' clean. /forums/images/graemlins/cool.gif
</font><font color="blue" class="small">( are u saying that when u want to change ranges, hi , lo or engage/ disengages pto, or switch from 4wd to 2wd you don't have to depress a pedal? )</font>
Exactly.
/ Pressure washer questions #12
I thought that was how all hydros worked!
Cliff
/ Pressure washer questions #13
</font><font color="blue" class="small">( Nope, no clutch at all. Forward pedal, reverse pedal, high speed/low speed selector and 2wd/4wd selector. The rest is all magic. )</font> Funny, I didn't even look at that on the Deere when I was first shopping, had been going for shuttle shift. It was not until much later that I turned to HST, and the ones I saw all had a clutch as well. So, I don't know of anything else you need to do, except that I would use your air hose after washing and blow out as much water as you can just to help avoid any rusting. Is there a place to grease your HST pedals? I would think if water could pool in any of their mechanisms you would really want to blow them out good afterward and lubricate with something. John
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2 WHEELBARROWS (A68842)
2 WHEELBARROWS...
PALLET WELDING SUPPLIES/TOOLS (A67714)
PALLET WELDING...
ALLMAND NIGHT-LITE PRO II (A68842)
ALLMAND NIGHT-LITE...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
