Pressure washer idle down
/ Pressure washer idle down #1
tjkubota93
Arlington, TN
Kubota bx1860
I have a pressure washer I got from my neighbor because it was broke. Turns out the pump was ate up from setting with purple cleaner in it.
It's a Honda motor with a cheap pump I bought as a replacement.
Is there a way to make it idle down like some new ones I have seen?
I haven't had a chance to study how that feature works.
/ Pressure washer idle down #2
There should be a lever above the carb toward the tank that controls engine speed on horizontal shaft engines.
Some times the lever will be stiff, if it is you can untighten the nut on the lever to make it easier.
/ Pressure washer idle down #3
What your are referring to is the "unloader" I believe...Pressure Washer Unloader Valve | eBay
Good Luck...
They all have that. I want to know how to hook it to the throttle. So when it unloads, it also idles down.
/ Pressure washer idle down #5
There is usually a "kick down" cable/linkage...how was it originally kicking down?
It just has the standard unloader valve. So the engine stays at the governed rpm, but the pump quits pumping. The new ones I have seen actually have a throttle control as well.
Rooster (A64557)
Rooster (A64557)
2008 Ford E-450 Super Duty Ambulance (A64556)
2008 Ford E-450...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
213097 (A64276)
213097 (A64276)
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
