pressure tank questions
   / pressure tank questions #1
randy41
Linden VA
there's a pressure tank on cl for $50. the seller says its 68 gallons, 4 1/2' high. is there a way to test it without actually hooking it up? if it holds air pressure does that mean its good to go? i don't want to pay $50 for an anchor.
could i plumb it in series with my present pressure tank giving me the capacity of both?
the goal is to reduce cycling without using a cycle stop valve.
   / pressure tank questions #2
If there is pressure in the top bladder when empty it should be fine. Should be about 25 to 30 Lbs typically as the pressure should be 2-3 Lbs below the cut in on the switch.
I would also ask why he is selling - going to city water etc. I have two in series on my well and it works fine. I think the 68 gallon size should give you about 9-10 gallons drawdown on 30-50 switch setting.
the seller says he's switched to a gravity fed system.
   / pressure tank questions #4
   / pressure tank questions #5
As Randy says, for a bladder tank, if it holds air fine. You don't want a non-bladder tank. Soem concern about tank leaks though. That could be tested by filling with water and closing the tank valve. Bladder wouild need to have pressure in it for the test.
Harry K
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
2012 WESTERN STAR  4900 SB INOPERABLE (A58214)
2012 WESTERN STAR...
CASE 610 Sprayer System 2000 Gallons (A56436)
CASE 610 Sprayer...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
2010 International Derrick Digger (A55973)
2010 International...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
