Pressure relief valve on a Case IH 1104
   / Pressure relief valve on a Case IH 1104 #1
lowdownwayne
Case IH 1140
Hi there, I am looking for knowledge on this valve. The main hydraulic pump produced a crack and spewed hydraulic fluid all over the engine compartment and the ground. While tracking down a replacement pump, I was told the most common cause would be the pressure relief valve not releasing, causing pressure to build up to the point it cracks the case. I am not sure that is the issue, but I did remove the valve to inspect it. Under the cap is the spring, poppet valve, pressure relief valve, and steel ball. The ball seems stuck in the pressure relief valve. Shouldn't it move freely? It looks like the bore in the pressure relief valve is larger where the ball should move, and the is reduced where the poppet valve travels.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2016 LOAD MAX 24 GOOSENECK (A52472)
2016 LOAD MAX 24...
JOHN DEERE TS LOT NUMBER 151 (A53084)
JOHN DEERE TS LOT...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
