Pressure relief valve on a Case IH 1104
   / Pressure relief valve on a Case IH 1104 #1
lowdownwayne
Case IH 1140
Hi there, I am looking for knowledge on this valve. The main hydraulic pump produced a crack and spewed hydraulic fluid all over the engine compartment and the ground. While tracking down a replacement pump, I was told the most common cause would be the pressure relief valve not releasing, causing pressure to build up to the point it cracks the case. I am not sure that is the issue, but I did remove the valve to inspect it. Under the cap is the spring, poppet valve, pressure relief valve, and steel ball. The ball seems stuck in the pressure relief valve. Shouldn't it move freely? It looks like the bore in the pressure relief valve is larger where the ball should move, and the is reduced where the poppet valve travels.
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A52472)
2018 WACKER NEUSON...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
