Pressure on quick connects
/ Pressure on quick connects #11
You must have posted while I was outside with my son in law. I will remember that for the next time. Thanks.
A few things I have learned...
There is more to it then that. On the Bobcats, you shut the engine down and turn the key all the way to the left but you also have to wiggle the foot pedals (rock them back and forth) to actually bleed down the pressure. The key alone doesn't do it. You continue to hold the key to the left when you're wiggling the pedals.
Oh, and when connecting/disconnecting hoses when the machine has been sitting for a while its best not to first start the machine. The pressure will frequently bleed off while it sits so its usually almost always easiest to work with the hoses when the machine hasn't been run for a while.
Don't leave the bucket or attachment in the air either...that will hold pressure on the hydraulics. Set the attachment down when you shut the engine off.
I thought the OP originally said he had removed the connections from the cylinder?? I must have misunderstood. Next time, and there will be a next time, loosen the hose connection at the cylinder or loosen the coupler connection from the hose and relieve the pressure. The pressure problem was evidently in your thumb cylinder rather than the machine. Flat face couplers are harder to drain pressure off without doing damage to the coupler mechanism. I learned long ago to uncouple hot, recouple cold.
After not being able to connect the one hose, I did remove both hoses from the thumb cylinder thinking pressure had built up in the cylinder after I connected the first hose. With both hoses connected to nothing I attempted to connect them to the machines quick connects. One hose went on as usual but the second one would not go past about halfway onto the machines quick connect. The pressure was coming from the machine.
A few things I have learned... There is more to it then that. On the Bobcats, you shut the engine down and turn the key all the way to the left but you also have to wiggle the foot pedals (rock them back and forth) to actually bleed down the pressure. The key alone doesn't do it. You continue to hold the key to the left when you're wiggling the pedals. Oh, and when connecting/disconnecting hoses when the machine has been sitting for a while its best not to first start the machine. The pressure will frequently bleed off while it sits so its usually almost always easiest to work with the hoses when the machine hasn't been run for a while. Don't leave the bucket or attachment in the air either...that will hold pressure on the hydraulics. Set the attachment down when you shut the engine off.
I did not know about turning the key left and manipulating the pedals. I tried to just move around the joysticks. The machine was sitting for about a week with all the hydraulics on the ground. If I would have known about the key maneuver I think I would have had no problem. Thanks again for the tip.
/ Pressure on quick connects #14
I just recently converted all my QD's to the skidsteer flushface type ... so brand new couplers and all appear to be of the same brand/manufacturer.
One thing I have noticed is that they seem somewhat sensitive to alignment ... get them slightly cocked and you're going to have an issue.
I can eliminate pressure as a possible cause, since this was with couplers which were not connected to anything and had never been installed.
/ Pressure on quick connects #15
/ Pressure on quick connects #16
Flat faced couplers are sure nice when it comes to keeping your connections clean, but without that built in relief of a skid steer, ag couplers allow simple pressure relief by tapping the male end on something. Wipe up and go.
/ Pressure on quick connects #17
Ahhhh,, got it now. :)
/ Pressure on quick connects #18
My FEL 3rd function is operated electronically. The only way to relieve tractor pressure is to shut off the tractor, then turn the key back on without starting the engine, then cycle the open/close buttons to relieve the pressure. Without that knowledge I'd have problems frequently.
IRanch IRMC High End Massage Chair (A60463)
IRanch IRMC High...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2012 PETERBILT 386 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2012 PETERBILT 386...
2014 PJ TRAILER GOOSENECK TRAILER 40' (A60736)
2014 PJ TRAILER...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
