Pressure in the hydraulic tank
   / Pressure in the hydraulic tank #1
SylvainG
Platinum Member
South West, Qc
Kioti LK30
So yesterday after using the box grader for several hours, I've reattached the backhoe to the tractor. I was first unable to connect the hydraulic lines for two reasons. First one was fluid in the backhoe warmed up from morning to afternoon. Had to drop one of the stabilizer to remove the pressure. Second, and is the one that I question with, was the pressure in the tank prevented me from connecting the return line. Had to slowly open up the tank's fill cap to release the pressure. Is this normal? When the backhoe was off the tractor, my remote valve (that supply the backhoe when in its 'release' position - it's a log splitter valve) was centered so hydraulic fluid was automatically returning to tank.
Thanks
   / Pressure in the hydraulic tank #2
I believe most tractors have the transmission reservoir vented to atmosphere to prevent damage to shaft seals. If this was my tractor I would be checking to verify if transmission reservoir is supposed to be vent and then locate that vent.
I just checked my user and service manual (LK30) and couldn't find anything with 'vent' in them :(
   / Pressure in the hydraulic tank #4
Printed or not, some venting is a must for any reservoir.
However in hydraulic lines buildup is common so depressing the connecting tip will relieve accumulated pressure, for the other side poking the inner connection accomplishes the same effect, that or a gentle attempt to couple usually relieves the pent up pressure.
A 'blip' of hydraulic oil is considered normal.
   / Pressure in the hydraulic tank #5
Yes, "tank" needs to vent.... May be some sort of vent hidden (not readily visible) on top of "tank" or maybe in tank filler cap and just plugged....
Dale
   / Pressure in the hydraulic tank #6
Hmmm... is yours a hydro drive machine? In my gear drive tractor, I noticed that some pressure builds up in the hydraulic tank. Enough that when I added a rear remote once, a burst of fluid came out when I removed a cover plate. I have no idea where the vent is, if there even is one. Have you ever taken the fill cap off and noticed pressure in the tank before this incident?
It's a gear tractor, not HST. I don't think I've noticed it before but it was the first time changing implement after using it.
I've contacted the dealer in case he knows where the vent is on that 10 years old tractor and I'll look for it myself later this week when I'm back at the cottage. I don't think there is a vent on the cap. I'll look more closely.
Thanks all.
I think I've found it in the part diagrams. #29 is described as "TUBE, BREATHER" in the "HYDRAULIC CYLINDER GROUP". If that's it, it's behind the fill cap so should be easy to spot.
Edit: Actually, that's the BACK of the tractor. I don't have that filler cap (#27) there but the return port for the backhoe. I've seen that #29 thing and I thought it was a hose holder lol. I'll see if it's plugged.
My filler cap is in another diagram (TRANSMISSION CASE GROUP), part #9. That picture above sits over that big #1 part below.
   / Pressure in the hydraulic tank #9
I have a vent on my tractor just like the one in the drawing, my dealer warned me that mud daubers will fill it up and cause problems. It's one of the things I check regularly on the tractor.
   / Pressure in the hydraulic tank #10
On my previous tractor, Mahindra 2615, the vent somehow got clogged. I ran a wire through the vent and no more issues.
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
UNUSED RAYTREE RMSG29-29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
