Pressure build up on front axle of a 4410 John Deere compact tractor
   / Pressure build up on front axle of a 4410 John Deere compact tractor #1
WJKS
South Porcupine Ontairo
1993 1035 Massey Ferguson, 2005 4410 John Deere
Are There any quick fixes to vent this front axle
   / Pressure build up on front axle of a 4410 John Deere compact tractor #2
Looks like for some JD front axles they redesigned the dipstick to be vented?
LVU33873 john Deere part number for other models.​
   / Pressure build up on front axle of a 4410 John Deere compact tractor #3
The front axle on my M6040 is vented. Dead center, top of the axle housing. A VERY difficult place to locate. It's a screw in plug with a nipple. Rubber hose attached to the nipple. Hose goes up - connects to a steel pipe - terminates in a 180 bend at the very top of the radiator.
Makes no mention of this in my Owners Manual. Had to put a small filter on the end of the steel pipe. Mud daubers like to fill the end with they eggs/goo.
   / Pressure build up on front axle of a 4410 John Deere compact tractor #4
I know this is an old thread but hopefully it helps someone.
I just drilled a 1/16th holeat the very end of the existing T shaped indentation in the yellow plastic dipstick cap. I stuffed some filter material in that same indentation to prevent any debris. Works well.. I am also using 80W/90 geear oll.
Bell B30E (A50123)
Bell B30E (A50123)
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2023 International MV607 Ambulance (A51692)
2023 International...
2008 Ford F-250 Service Truck with Liftgate (A51692)
2008 Ford F-250...
2015 Chrysler 200 Sedan (A53117)
2015 Chrysler 200...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
