Pressure adjustment in Centrifugal Pump
   / Pressure adjustment in Centrifugal Pump #1
Arjun1
How to adjust the pressure in centrifugal pump ? detailed process pls.
thanx.
   / Pressure adjustment in Centrifugal Pump #3
Centrifugal pumps are pretty limited to "pressure adjustment".
Diameter and RPM is pretty well determining factors in a reachable "head pressure". The impellar basically throws the liquid.
Now if this pump worked fine and started losing developed head, and assuming impellar is fine, wear ring is worn enough that internal leakage may be the biggest problem. I have worked around Sulzer pumps, and some of them have an adjustable wear ring. Packing can also cause some problem to pressure, but most of time it will create cavitation.
   / Pressure adjustment in Centrifugal Pump #4
Some times the impeller is shaved down for less capacity. This is a non reversible operation.
With some types of stacked impeller pumps impellers may be removed. With this type of pump a hole may be drilled through the diffuser?? to reduce capacity.
With impeller pumps flow is usually controlled by a discharge side valve or bypass valve or both.
   / Pressure adjustment in Centrifugal Pump #5
Egon, you are correct. I have that Tim The Tool Man Taylor thought of more power!!!! Maybe he wanted less flow, or pressure.
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2015 Kubota BX25D (A50123)
2015 Kubota BX25D...
2014 Ag Spray Schaben Sidedresser (A53473)
2014 Ag Spray...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
84'' skid steer bucket (A53421)
84'' skid steer...
