Pressure adjustment in Centrifugal Pump
   / Pressure adjustment in Centrifugal Pump #1
Arjun1
How to adjust the pressure in centrifugal pump ? detailed process pls.
thanx.
   / Pressure adjustment in Centrifugal Pump #3
Centrifugal pumps are pretty limited to "pressure adjustment".
Diameter and RPM is pretty well determining factors in a reachable "head pressure". The impellar basically throws the liquid.
Now if this pump worked fine and started losing developed head, and assuming impellar is fine, wear ring is worn enough that internal leakage may be the biggest problem. I have worked around Sulzer pumps, and some of them have an adjustable wear ring. Packing can also cause some problem to pressure, but most of time it will create cavitation.
   / Pressure adjustment in Centrifugal Pump #4
Some times the impeller is shaved down for less capacity. This is a non reversible operation.
With some types of stacked impeller pumps impellers may be removed. With this type of pump a hole may be drilled through the diffuser?? to reduce capacity.
With impeller pumps flow is usually controlled by a discharge side valve or bypass valve or both.
   / Pressure adjustment in Centrifugal Pump #5
Egon, you are correct. I have that Tim The Tool Man Taylor thought of more power!!!! Maybe he wanted less flow, or pressure.
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
(10) 24' Free Standing Panels (A50123)
(10) 24' Free...
2025 K4525 UNUSED Double Garage Steel Barn (A53117)
2025 K4525 UNUSED...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
