Pressing on axle bearings
/ Pressing on axle bearings #1
Big Irish
collinsville il.
ford 2000 & ford 900
Have to replace bearings on rear axle and they're the press on type with a press on retainer. Old ones wasn't installed properly so I was able to remove with torch. Is there any way I can press on new ones without a press? Any home tool ideas? Thanks
/ Pressing on axle bearings #2
Use a vice.
/ Pressing on axle bearings #3
I've done it in a walkway between the house and garage. Both had cement foundations high enough up so I could put a bottle jack sideways on one side and the axle on the other. As long as the pump is on the bottom the jack will still work. A hammer would also work in a pinch but you risk doing damage so it would be a last resort.
/ Pressing on axle bearings #4
Get some dry ice for the axle and put the bearing in a can of oil, heated to about 175 degrees. Should just slide right on.
/ Pressing on axle bearings #5
I've done it with a big c clamp with a jack handle on the clamp handle for a cheater. Even using dry ice I learned some new curses. In the end it worked though. This was used with the bearing seating bushing like you would use properly in a hydraulic press.
Winco 12T Fertilizer Tender Box (A66408)
Winco 12T...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
2007 Roadmaster Camelot Monaco Motor Home (A62613)
2007 Roadmaster...
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
New Idea 201 Manure Spreader (A66408)
New Idea 201...
2004 John Deere 8320 (A63688)
2004 John Deere...
