Pressing on axle bearings
/ Pressing on axle bearings #1
Big Irish
collinsville il.
ford 2000 & ford 900
Have to replace bearings on rear axle and they're the press on type with a press on retainer. Old ones wasn't installed properly so I was able to remove with torch. Is there any way I can press on new ones without a press? Any home tool ideas? Thanks
/ Pressing on axle bearings #2
Use a vice.
/ Pressing on axle bearings #3
I've done it in a walkway between the house and garage. Both had cement foundations high enough up so I could put a bottle jack sideways on one side and the axle on the other. As long as the pump is on the bottom the jack will still work. A hammer would also work in a pinch but you risk doing damage so it would be a last resort.
/ Pressing on axle bearings #4
Get some dry ice for the axle and put the bearing in a can of oil, heated to about 175 degrees. Should just slide right on.
/ Pressing on axle bearings #5
I've done it with a big c clamp with a jack handle on the clamp handle for a cheater. Even using dry ice I learned some new curses. In the end it worked though. This was used with the bearing seating bushing like you would use properly in a hydraulic press.
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
Mayrath 10 x 63 Swing Away Auger (A66408)
Mayrath 10 x 63...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
