Press in zerks...
/ Press in zerks... #1
JSharp
Platinum Member
Central Illinois. No, not Chicago.
IH 404, Cub GT 2554
Why in the world did Cub use these crappy press in grease zerks on such a nice machine? When I had my deck off at 10 hours to grease and check everything out I had one that wouldn't take grease and another that pulled out. The dealer fixed them when it was back for the steering recall.
Had the deck off again this week at 25 hours to grease everything. Another zerk now won't take grease and the lower one that greases the steering shaft is falling out. It looks like the hole in the bracket is too large for a press in to stay.
I wonder if I should have the dealer come get it and fix it with more crappy press in zerks or fix it myself correctly with threaded ones that can actually be changed if they have problems...
/ Press in zerks... #2
Most likely to save $$$$$ they used the press in zerks. I would just fix them the right way and be done! Let us know what you decide!:)
/ Press in zerks... #3
This came up a while back when I had the same problem with the press in zerks falling out with MTD replacement spindles used on my old IH 44C deck. Just the pressure from the grease gun would pop them out on the new spindles. I invested in threaded zerks and used a bottoming tap (both available at better hardware stores for a few bucks) to make the threads. I tried using loctite on the press-in zerks but they still popped out- they should be outlawed!
-Fordlords-
/ Press in zerks...
Fordlords - I was probably one who thought Loctite woud work. I guess you've answered that for us. I think I'll pick up a box of threaded zerks and just change them out as needed.
Did you have to drill the holes larger before you tapped them or were they close enough to get the tap to start? If they are it would certainly simplify it. I'd rather not have to take everything apart...
/ Press in zerks... #5
In my case I did not have to drill the hole out larger, the bottoming tap started into the spindle fairly easily- I did have to block the spindles underneath using the blades to keep them from spinning. The threads are soft, but do not leak grease and the zerks stay put- I did put some Loctite on the zerk threads to be safe.
-Fordlords-
/ Press in zerks... #6
Fellas, do the press in zerks still have a hex head on them? I've been lucky with my 2544, have not lost a zerk yet. Some do take some finagling to take grease, but so far so good.
Thanks
Joel
/ Press in zerks... #7
Thanks
Joel
The ones I had all had round heads on them.
Bob B.
/ Press in zerks...
All of the ones on my tractor are round except the 3 in the top of the deck spindles. Those have hex collars so I'm guessing they're threaded.
I picked up a package of 1/4" X 28 threaded zerks and I already have a bottoming tap and drill if I need one. I'll be replacing them as needed. Think I can send the labor bill to MTD? :lol:
/ Press in zerks... #9
Yep, send the bill to MTD :)
Usually if there is a hex head, the zerk is threaded the hex head being used to tighten it. My deck spindles were MTD replacement parts, and had press ins, about the last place you want them with the vibration and spinning. I will admit the MTD spindle bodies I think are better than the original IH parts, the MTD's being a heavy aluminum casting. The old IH spindles were made from steel stampings that rusted badly.
-Fordlords-
/ Press in zerks...
The cast spindle housings on mine look to be heavy duty and good quality. In fact, the whole deck looks that way and is one of the reasons I bought the tractor in the first place. If it weren't for the silly press in zerks my complaint column on this unit would be about empty. Give me real zerks and a larger gas tank and I'd be hard pressed to find anything at all to (complain) about. Truly a rarity for me... ;)
/ Press in zerks... #11
Upon further review, I think pretty much all the zerks are head-less press-in's on my 2544. I've been lucky so far as non have popped. I'm only about a 2-3 pump guy as it is (yikes) & don't hit'em too often, so I'll have to continue my light touch. :)
Joel
/ Press in zerks... #12
For all you guys out there thinking about tapping your zerk holes be aware that tapping creates small chips that must be flushed out before inserting the new fitting. If you don't clean them out they will be forced into your bearings causing premature failure. The only sure way to prevent this is to completely clean out whatever part your working on after tapping.
/ Press in zerks... #13
Put a little grease on the tap, the metal shavings will stick to the grease.
/ Press in zerks...
I thought about this previously and agree if it were one of the high speed roller bearings on the deck. I'd pull them apart before I tried to tap them. But I think the sleeve bearings on the deck wheels and idler arms and steering should be ok. Either the clearance is close enough it should stop whatever chips don't stay on a greased tap from getting into the the bearing, or it's loose enough that flushing it out with fresh grease when I'm done should take care of the problem. I intend to clean the holes out with a q-tip and some solvent before I put the zerk in anyway just to be sure.
I admit that's a guess, but it makes sense to me...
/ Press in zerks... #15
I just did the q-tip with some oil on it deal after I tapped the threads for the spindles. Thankfully with this job, very few threads have to be cut to install the zerks. Had I known the press in zerks would be a problem, I would have done it the best way by taking the spindle apart to tap it and flush the shaft out before I installed them. I think as long as you keep things as clean as possible and clean the threads and holes after you tap them as mentioned, you should be OK.
-Fordlords-
2018 Manitou MLT634 7,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
PORTA POTTY (A67714)
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2018 GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
2018 GENERAC...
2008 Sterling L7500 Series T/A Vactor 2115-824 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
