Press in Zerk fittings
   / Press in Zerk fittings #1
Morkai
Tifton, GA
'05 Cub Cadet GT2544, HDS3165, HDS3225
I had one pull out of a front spindle, and damaged beyond repair trying to get it loose from the grease gun. What size should I get to replace them with threaded fittings?
   / Press in Zerk fittings #2
What ever size you decide to tap the hole. Standard I believe would be a 1/4-28 zerk fitting. Drill a 7/32" hole and tap it 1/4-28.
Joel
Man, too do all that I'd have to break it all down and make sure there are no metal shavings inside as well. That would mean dropping the front axle. Maybe just trying to loctite a new press in fitting would be best. What size is the original fitting?
   / Press in Zerk fittings #4
When you drill and tap, put some grease on the drill bit and tap.
The metal shavings will stick to the grease.
It's still going to push some shavings into the inside and with all the grease it won't be easy to get out.
   / Press in Zerk fittings #6
A way to clear the hole of shavings is to hose it out first with whatever then use an inflator for basket balls and stick it all the way to the bottom of the hole. Plus you aren't going to damage anything with a few particles of metal..
Well, I picked up some 1/4-28 fittings at Tractor Supply, so I guess I'm gonna try tapping them. I'll prob just take the hole axle off and apart. That's a good idea about the needle inflater, I have one.....somewhere. :)
   / Press in Zerk fittings #8
I once owned a 1973 Mercury Capris, back when "permanently lubricated - never grease" became popular. There were no grease fittings or even holes for them. The tie rod ends froze up and made a horrendous squeaking noise. I drilled, tapped and flushed the holes out with a spray can of degreaser. and installed zerk fittings. Those tie rod joints were still on the car many years later when I traded it in.
Bob B.
   / Press in Zerk fittings #9
I'm starting to think most of the problem with the press in zerks is that they aren't installed correctly. The factory just doesn't drive them in far enough.
I had a few fall out on my 2554. A couple I tapped out 1/4 X 28 and used thread in parts. But a couple of others I couldn't thread easily so I just drove in new press in parts and made sure they were in all the way.
I've had no trouble with the ones I installed...
   / Press in Zerk fittings #10
When removing grease gun from drive in zerks it helps to loosen the tip if it feels too tight. I leave mine finger tight so I can adjust for different zerks. The new zerks are shaped different than the old style and don't seem to want to let go.
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
Sterling 9500 (A53473)
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
FAKE (A52472)
FAKE (A52472)
2017 Ford F-350 Crew Cab Service Truck with Liftgate (A51692)
2017 Ford F-350...
2019 Polaris Ranger XP 4x4 Utility Cart (A51694)
2019 Polaris...
