Grading Prepping to plant grass seed
   / Prepping to plant grass seed #1
Engine Mike
Rochester hills michigan
Kubota B2320
I have a large lot that I plan to plant grass. The lot is uneven and needs to be smoothed. What is the best way to do this?
   / Prepping to plant grass seed #2
What implements do you have to work with?
Nothing yet. Brand new tractor. Kubota B 23 HP 4WD. Trying to decide the best implement to rent or buy to do the seeding prep.
   / Prepping to plant grass seed #4
I recommend you rent a tiller or Harley rake if the ground has surface rock to windrow and pick up. Most of the time I use a tiller now followed by a pine straw rake and water filled roller. Fpr lawn areas that need lots of larger dips and bumps removed I use a landplane grader scraper. Just depends on the lawn and condition.
   / Prepping to plant grass seed #5
First, spray to kill existing vegetation. Then rototill to loosen the soil and break up existing vegetation roots. If the field has not been worked and has been vacant a long time you will probably have to rototill multiple times to get it broke up fine enough for grading. Use a back blade or box blade to move dirt to get the grade you want. Box blade is better if you have to move a lot of dirt. A harley rake is a great tool for breaking up root clumps and collecting surface rocks, but it may not be practical with your small tractor. Try a landscape rake with gauge wheels. The gauge wheels will help get the final grade level.
   / Prepping to plant grass seed #7
A pulverizer and drag harrow is what I use, If the ground is uneven (mounds and holes) the pulverizer will drag down the mounds and fill in the holes as well as rake out any roots/rocks, It won't get 100% of them, I follow up with a drag harrow and then use the pulverizer one last time. I adjust the link so when I lower it only the roller touches the ground allowing it to punch small holes in the ground so the seed will in-bed into them,
Spread the seed, cover in wheat straw, and then throw out a little 10/10/10, and pray for a light rain, ( Not a flood )
Note : if you are sewing grass on a hillside/ Slope you can drag the pulverizer cross-way allowing the spikes to lay out small ruts, this helps to prevent the seed from washing away,
If you haven't done so already I would watch a few video's on the procedure,
How To: 72" Pulverizer Yard Tool for Tractor 3point Hitch - YouTube
   / Prepping to plant grass seed #8
Don't know what kind of grass your planting, but the replies so far are much in line of what I do. I just do one more thing, I rip the ground as deep as I can so the roots will take deep. Helps when in periods of drought, the deeper the root system, the hardier the plant will be. Drought is not a problem here this summer! Oh the main grass I plant is Bermuda, in the yard or pasture. LUTT
   / Prepping to plant grass seed #9
I used a 29hp tractor to prep a 4-acre field about 3 years ago. Turns out what worked best was a rototiller, but had to do it twice about a week apart. First time through will kill the grass and weeds, but ground is chunky. Second time through the ground is dry and tilling will even out the clumps. Also you may have to use a loader to push dirt around if you want to improve drainage or create slopes.
As far as grass planting, I just walked through the field with a bucket of grass seed and spread it by hand in the wind. Took about an hour to distribute 100 pounds of seed by hand (two 50-lb bags purchased from feed store). Field has been growing orchard grass perfectly well ever since, and have not had to re-seed or re-till yet.
I see people also dragging heavy railroad ties or similar stuff behind their tiller. I tried using a harrow but it got clogged instantly and was not heavy enough to make any impact. Harrows and rakes work on sandy areas or clean soft dirt, but not on freshly prepared chunky dirt and weeds.
Rooster Weathervane (A55853)
Rooster...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
