Snow Blade Premature Skid Shoe Failure
   / Premature Skid Shoe Failure #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
This is my first season plowing with a Landpride STB1596 FEL plow. I maintain 1.25 miles of gravel road and several 300'+ driveways. Both skid shoes on the landpride failed halfway through the winter season. (about 6 snow storms) Previously, I used Western plows with my tractors and pickup trucks. The Western skid shoes lasted 3 or 4 seasons (30 to 40 storms).
The OEM replacement shoes are around $153 per pair. At that price, you'd think they would last longer than part of a season! Since the Western shoes are $52 a pair and last 5 times longer, I bought a pair and modified them to fit the Landpride. I used a short piece of pipe to shim out the 1" shank of the Western shoe to match the 1 1/4" shank of the Landpride. I finished the plowing season (I hope), 6 more storms, with only minor wear on the Western shoes.
I'm not sure what the deal is here but I'm not happy with Landpride at this point.
   / Premature Skid Shoe Failure #2
Get some hard-facing rod and weld cross-hatches onto wear surfaces. You'll want to preheat the parts and allow slow cool-down under folds of a f-glass welding blanket. You should get a Rockwell-C hardness in the high 50s with such.
Auto Value : Hard Facing Stick Electrodes Supercote Forney FOW 4241 1. lb 5/32" Diameter
I've seen this used to build up bush hog blade edges, :rolleyes: and had to use resin-bonded diamond wheel to 'clean up' vs beating-up ('down' lol) a 'green' vitreous wheel.
btw, the BH is now mine, and edge welds aren't as brittle as I cautioned. (seems no shattering under impact)
t o g
   / Premature Skid Shoe Failure #3
Never heard of wearing out skid-shoes.Part of the problem is the design of the that particular plow;weight of the plow and FEL on the shoes.Mine is a chain mount(floats the plow) so only the weight of the plow is on the shoes.
You may want to try a rubber edge on your plow.
   / Premature Skid Shoe Failure #4
I see a lot of them used as door stops or get junked for scrap
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A51039)
2019 Energreen EVO...
2005 STERLING LT8500 SERIES MIXER TRUCK (A50854)
2005 STERLING...
2020 MACK PINNACLE (INOPERABLE) (A50854)
2020 MACK PINNACLE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
