Preheating question
   / Preheating question #1
camshawn
Langley BC
Mihindra 3616
I am about to weld some ears for mounting a hydraulic cylinder on my back blade. The welder at work recommender to preheat them before welding (1" thick onto 1/2" backing plate). I did not think to ask him how hot to get them before welding.
Thanks, Cam
   / Preheating question #2
That can be a loaded question, but most of us here welding mild steel anything over 50-degrees is enough. But here is a good article on pre-heating.
What is Preheat?
Thanks for the quick reply. One of the things I love about this site.
I will read the article. Everything I am using is mild steel. I think that preheating gives better penetration on the thicker pieces. Is that correct?
Cam
   / Preheating question #4
If your welding machine is under powered, it sure can't hurt! Proper joint prep is key also!;)
If I manage to stop procrastinating, I will grind off the mill scale, preheat until warm (100 deg F) weld 3 passes (t joint), with 035 wire, about 430 inches, 23 volts, 85/15 gas.
It is. Hard to get moving when it is raining out and the coveralls are going to be damp. Inside is warm and dry and has the internet. Thanks for the preheating link Shield Arc
Cam
   / Preheating question #6
Oh wow! Is .035 the biggest wire your machine will run? The 85/15 gas is a big help. Any chance your welder can produce more volts so you can get into spray?
Put your numbers into the this calculator, and you'll see my concerns!
Miller - Welding Calculators
I see what you mean. I would be better to use stick and 7018 for this heavy material. My thermal arc 211i maxes out at 210amps
Cam
   / Preheating question #8
The .035 wire sends up red flags to me!:eek: I wouldn't think twice about 1/8-inch 7018, 5/32-inch would be better.;)
Here is some spray I did with my V350-Pro with .035 wire, and C/10 gas.
I will use the 7018. 1/8 is what I have here. With the cold coming next week in southern BC, snow may come with the warming and I need to get this back blade finished. Off to clean and weld, Cam
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2013 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2013 MAXEY TRAILER...
1042 (A50459)
1042 (A50459)
2021 Dosko 337S-13HC Walk-Behind Stump Grinder (A49461)
2021 Dosko...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
