bigballer
Platinum Member
- Joined
- Jun 2, 2006
- Messages
- 666
- Tractor
- 2006 Kubota L3400
My tractor has 13 hours on it now and I've been religous about checking the oil and hydraulic fluid before running and I also like to check underneath the frame and look for any obvious issues, loose bolts, etc. Well yesterday I was bushhogging and at one point noticed the a pretty strong smell of fresh oil, wasn't sure if it was hydraulic or motor, at any rate the smell quickly came and went. I checked all the hose connections and everything seemed to be intact. On my way I went. Well this morning before I started it up, I opened the hood to clean the radiator screen and happened to look at the oil cap on top of the head. I noticed quite alot of oil built up around it and some indictations that it had moved it's way down the front of the motor. I gave it a twist, and sure enough it was about a 1/8 of a turn loose. Apparently enough for some of the oil to get pushed out of the engine and make it's way to places unwanted. I spent the next 15 minutes cleaning it up. Anyway, I am glad I checked it and of course it's now on my inspection list prior to starting any work.
So I am curious, Do you complete pre-flight inspections and what is the typical thing you find needing attention? Is there anything bad that's happened to your tractor as a result of not inspecting?
cheers,
bigballer
cheers,
bigballer
