Pre-fill Kohler Oil Filter - Really Necessary?
   / Pre-fill Kohler Oil Filter - Really Necessary? #1
stubborn
Tulalip, Wa (U.S.)
Cub Cadet LT1050
Member "KJO" says in this thread:
"Kohler recommends that prior to installing the new filter on the engine, that you first fill the new filter with new motor oil and let it set for several minutes so that the filter material will absorb the oil, then refill the filter and install it on the engine. This procedure is probably used in an attempt to prevent the engine from operating for a short time without oil after an oil change. These engines are also protected by an low oil shut down switch which could likely cause problems with starting if the procedure is not followed."
I am new to Kohler engines but I did not see this advice in their Maintenance Tips. Is this good advice?
   / Pre-fill Kohler Oil Filter - Really Necessary? #3
This is good advice when changing the oil filter on any engine.
   / Pre-fill Kohler Oil Filter - Really Necessary? #4
   / Pre-fill Kohler Oil Filter - Really Necessary? #5
Yep - always try to stuff as much oil as I can get into the filter without drooling all over the place when screwing it on. Couldn't hurt.
   / Pre-fill Kohler Oil Filter - Really Necessary? #6
   / Pre-fill Kohler Oil Filter - Really Necessary? #7
I agree with Mike.. I prefill all filters... oil, fuel. hyd... etc.. ( I even prefill my air filters /forums/images/graemlins/smirk.gif )
Soundguy
   / Pre-fill Kohler Oil Filter - Really Necessary? #8
Soundguy
   / Pre-fill Kohler Oil Filter - Really Necessary? #9
Definitely pre-fill. These guys are 110% right.
   / Pre-fill Kohler Oil Filter - Really Necessary? #10
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
2017 Ram 5500 Crew Cab Reading Service Truck (A52377)
2017 Ram 5500 Crew...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
