Pre drilled holes? In bucket
   / Pre drilled holes? In bucket #1
whitmerlegacyfarm
Central PA
2010 Kioti DK50SE HST w/ 401 Loader
Hey guys my new dk50 hst shows up in mornin. Does the buckets have the holes pre drilled for a tooth bar? Was curious. Ifnot I was goin to c if they are able to drill those holes so I wouldnt have to once my toothbar shows up. Dont have the tools to dril threw that thick of steel. My neighbor does though lol. Thanks guys I will post pics as soon as I get a chance. Rain,is in forecast for the next 5 days so lil down I mite not get to use much. Thanks
   / Pre drilled holes? In bucket #2
Never have seen a bucket pre drilled for a tooth bar. I would wait till I had the tooth bar to make sure the holes were in the right place. :thumbsup:
   / Pre drilled holes? In bucket #3
Toothbars don't have standardized mounts so you really need to fit the toothbar yourself and then drill the holes. The good news is that bucket sides are usually only 12 or 14 gauge or so and drilling the holes is easy even with homeiwner grade tools. A bolt on cutting bar is different and drilling for that could be a real pain.
   / Pre drilled holes? In bucket #4
well, my 2011 - DK45 has several sets of holes predrilled in the bucket. 6 on the lower lip and 2 on each side......guess there for a toothbar....but i dont like using toothbars, so for me it didnt matter. see pics
   / Pre drilled holes? In bucket #5
my bucket sides are 3/16" steel...14 gauge is awfully thin
hmmmm... So as far as clearin brush n wantin to do a lil level of ground wat options are thete other then a tooth bar? Are there issues using them or something?
   / Pre drilled holes? In bucket #7
I'm not sure what the holes on the side of your bucket are for.
But they are way to high to be for a toothbar.
   / Pre drilled holes? In bucket #8
its just the kind of terrain i have, no real brush.lots of gravel and dirt. the tooth bars tend to leave grove marks. the plain bucket leaves it smoother. i guess it depends on the kind of terrain you have.
Ive rented equipment in the past with tooth bars, great for digging holes, and moving out dense underbrush. I just don't have this.
anyways, I'm not sure if the holes in my bucket are intended to fit a certain brand of toothbar or if there universal. I'm not sure what kinds of attachments Kioti sells under its own branding.
I have ordered a set of pallet forks for mine, and i hope that these will help me when clearing logs, branches, etc. time will tell. There due to arrive this Monday.:) :licking:
   / Pre drilled holes? In bucket #9
im not sure what the side holes are for. im refering to the 6 lower holes. the side holes may be for some kind of grapple???? id love to find out what there for. the dealer isnt even sure what there for.
   / Pre drilled holes? In bucket #10
The 6 lower holes are for a bolt on cutting edge/wear bar.
2009 UTILITY TRAILER MFG. CO. SEMI TRAILER 57 (A52472)
2009 UTILITY...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
JOHN DEERE RC7 R LOT NUMBER 224 (A53084)
JOHN DEERE RC7 R...
378851 (A51573)
378851 (A51573)
2016 John Deere 318G Skid Steer Loader (A51573)
2016 John Deere...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
