Prairie Prep with BCS 852
   / Prairie Prep with BCS 852 #1
PhilG327
Bronze Member
La Farge, WI
BCS 852
I am hoping to start work on establishing some prairie on part of my SW Wisconsin farm next year. After killing everything off (burning) and replanting prairie seeds, one of the steps in the process is to mow the future prairie down to 6" allowing the prairie plants to outgrow the weeds that come back after everything has been killed off. Any suggestions on how to modify or adjust a BCS 852 to cut at 6 inches ? I have a sickle mower which cuts right at the ground level, and a brush hog attachment which cuts at about 4 inches. I was thinking about adding some wheels to the sickle mower to raise the cutter, but then the BCS will be sitting at a very odd angle (plus this will be a long slow cutting job). Best option I can think of is taller tires, but how do I raise the mower deck off the ground ? Any and all suggestions welcome !
   / Prairie Prep with BCS 852 #2
Joel @ Earth Tools sells wheels for a sickle bar mower. BCS Implements
Thank you ! I did not know such an item was available. I think with taller tires, this might be just the ticket.
2019 John Deere 5090R Tractor (A52384)
2019 John Deere...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
10 in Small Excavator Bucket (A52377)
10 in Small...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
