PowerTrac Customizations
   / PowerTrac Customizations #121
Re: PowerTrac 1845 4 n 1
When he last posted about it, MossRoad was planning to try a 6 foot box blade on his 435.
You're right that any number of attachments can be adapted, not only from 3-point, but from skid steers.
   / PowerTrac Customizations #122
<font color=red>Relative to the hoe/rearward weight bias the problem is not too much weight on the rear but rather too little on the front to get sufficient downforce to dig hard ground. </font color=red>
Makes sense, but I've already proven to myself, at least, that the digging capability is in the curl of the bucket, not the download on the dipper. I was told that's true of all hoes, but my source isn't a recognized expert. No one is going to claim that an 1845 with a front hoe will compete with the real thing, but I think it will dig pretty well for the few times I need it, for a lot less money than a TLB or frame or 3-point backhoe. And, with the thumb I can pick up stuff with more reach than the 4 n 1 can give me.
   / PowerTrac Customizations #123
<font color=red>I'm not sure that's what's called self leveling</font color=red>
Charlie, Well at least that's what I meant by self leveling and I'm pleased to get this report. Interestingly when I as best I could scaled the linkage from a side on photo in the 1430 brochure, plotted it out and then raised and lowered it on paper, I came up with just about the same range of motion you measured and about 30 degrees of bucket tilt from top to bottom. I'm certainly glad to hear my scaling is wrong! The linkage geometry must be fairly critical.
John
   / PowerTrac Customizations #124
<font color=red>No one is going to claim that an 1845 with a front hoe will compete with the real thing, but I think it will dig pretty well for the few times I need it, for a lot less money than a TLB or frame or 3-point backhoe.</font color=red>
Charlie that's just the situation I have here and just what I want to accomplish.
<font color=red>And, with the thumb I can pick up stuff with more reach than the 4 n 1 can give me.</font color=red>
Ooh! A thumb! I see no thumb in your "hoe" & "hoefull" pictures. I want one. One of my desires is to be able to pick up half buried rocks in the woods where I can't reach with a bucket. I've been thinking of building a thumb & two finger log loader type grapple to do that. The hoe & thumb seems the way to go. How much if I may ask, did this arrangement set you back?
John
   / PowerTrac Customizations #125
If the PT425 will handle a 6 ft box blade, the 7 ft blade my local dealer has ought to work on the PT1845 Seems a bit much to me though. Charlie, you somewhere mentioned you thought the PT1845 was closed to 3000 lbs than to the 1800 lbs shown on their literature. You still think that?
John
   / PowerTrac Customizations #126
John:
Check with MossRoad re the box blade test. He may not have done it yet. He had the blade before he got the PT425 and was going to try it, but wasn't sure it would handle it.
Re: 1845 weight. If you look at the website, the 1430 is listed at 2600 lb. and the 1845 still at 1800. I asked about it and I think it was Chris who told me it was closer to 3000 lb. Mine certainly is heavier than 1800, since I think I've probably had 1500 in the bucket and driven around fine. Kristie Asbury has assured me that a group is working on updating brochures and the website, but I haven't seen much change.
The hoe, with everything, has cost just over $2,000.
Extenda Boomer $1,150.00
12" Bucket $290.00
Cylinder & hoses $225.00
Scraper $35.00
Thumb $120.00
Subtotal $1,820.00
Shipping $150.00
Total $1,970.00
See Lackender website.
Re the self leveling, Hans Luginbuhl (bubender) reported a while back that one thing he does with his PT425 is to pick up his other machines and implements on the PT forks, lift them above fence height, and then drive the PT through customers' narrow gates. That way he gets wider mowers, etc. inside. If the forks tended to tilt, I think he and his men might have busted up some equipment.
I've given myself a lap full of dirt when flicking the joystick with the bucket full of light dirt. The hydraulics are extremely powerful near the end of the stroke. The bucket is not self leveling. So therefore, the forks aren't either. You just have to be careful when lifting something and keep adjusting the angle of the forks. It is not that bad, as I am used to it with my IH 2500B. BIG bucket, 10' + lift height. I was glad that I had a cab on that thing/w3tcompact/icons/smile.gif
I didn't realize you had the thumb on your hoe. That would be handy for grabbing stuff.
I haven't done the 6' blade thing yet, but I'll state again, that while it will lift it with no problem, I doubt that it will pull it with any kind of efficiency. It is sitting in front of my garage waiting for a good day and some angle iron.
   / PowerTrac Customizations #130
Re: PowerTrac bucket/fork angles
John:
Your scaling from the 1430 has me concerned - not about the utility of the machine, but about the accuracy of my impressions of my own machine. I'm a novice operator, and have often curled the bucket the wrong way, although that's becoming a rarer event. I've not actually measured any angles except the limit ones I reported. (Not a 2 degree eye - a protractor.) In normal use, my main impression has been of minimal or no bucket curl as I've lifted things. If it turns out to be 30 degrees, I'll have to get my eyes recalibrated. Certainly MossRoad is a better observer and he says his isn't self leveling.
Bubenberg, PT Rich, other PT users?
2012 Chevrolet Traverse SUV (A55853)
2012 Chevrolet...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
