powermaster 861 smoking
   / powermaster 861 smoking #1
lynrob
Mid-Willamette Valley Oregon
Kubota L4740, MF65, Gehl 4610
I am considering buying a powermaster 851/861 diesel from a guy who just completed a bottom end engine rebuild. He said when he bought it the engine was seized. He investigated and found a bad piston and a bent rod. He pulled all the pistons and replaced rings and bearings, etc. Put it all together and the engine ran but had a lot of blue smoke (less when warmed up). He then replaced the injector pump but not the injectors and the smoke remains.
My question is what might cause the smoke? He says he has run it for about an hour since the rebuild so I would assume that the rings have seated. The smoke seems to follow the throttle to some extent. Definitely more smoke just after increasing the throttle. We didn't have any way to put it under load at his place. Could the injectors be worn out and just letting too much fuel in? I'm wondering if the smoke is just raw fuel.
Also, I called it an 851/861 because the serial number is rusted out. The only numbers we could read were the last two, '77'. He said that when he first bought it, the clutch was "funny". Once the tractor was moving, he could put the clutch in halfway and it would stop. If he put the clutch in all the way to the bottom, it would start moving again. He adjusted the linkage and changed the hole in the linkage that the clutch lever goes into. Now it acts like a single stage clutch... push it down and the tractor and pto stops lift it up and they both start. Could this be a bad two stage clutch that is now way out of adjustment or is it more likely to be a single stage clutch that is now more properly adjusted?
Other than that, and needing a voltage regulator, it isn't in bad shape, considering its age. Seems like it might be a good second tractor and a fun restoration project but I don't know a lot about the engine and don't want to buy a boat load of trouble. He wants $4000 for it I thought I might offer $2500. Thoughts?
   / powermaster 861 smoking #2
I'd walk.
1, i heard lower.. and rings. did he also hone the cyl or install sleeves?
smoke could be valve guides/seals in the head too. if it's blue smoke and not black smoke.. i doubt it is the injector pump.
that clutch issue is odd. if it was a dual clutch in the correct setting on pedal, half depressed stops forward movement, and full depress stops pto
you can get a good running 8XX tractor that actually WORKS for 2500$
soundguy
Thanks Soundguy. That is the conclusion I had reached too. I appreciate your feedback.
lynrob
   / powermaster 861 smoking #4
yep.. i didn't hear about any 'head work' and there should have been.
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
2001 FREIGHTLINER FL70 WATER TRUCK (A51247)
2001 FREIGHTLINER...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
SENTRY 100 STATIC GUARD (A51248)
SENTRY 100 STATIC...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
