Rake Powered rake
   / Powered rake #1
ICGREEN
Pendleton IN
JD 3520
Have any of you had experience with a powered landscape rake. Landpride builds one and I was just wondering if they're any better than the unpowered version.
   / Powered rake #2
ig, i HAVE AN 8' gLENMAC/hARLEY POWERED RAKE AND CAN TELL YOU THAT OTHER THEN THE TRACTOR, IT IS THE MOST USEFUL PIECE OF EQUIPMENT YOU CAN OWN. tHE POWERED RAKES ARE INCREDIBLE. Opps, sorry just realized I had caps lock on. I think once one has a powered rake, it will find many uses. Tags on this board has one as well. I'm sure Landprides would be fairly comparable to the Harley. A very, very useful piece of equipment. My favorite. Rat...
   / Powered rake #3
I am looking seriously at the "72'' 17 series" from Landpride. I think the #'s are correct. The Landpride is one awesome looking rake. I know Harley Rakes have 2 different versions, one that does much better according to others. I think everyone likes the one with round carbide dimples. The Landpride has this similar type of design as well as large tires which I like. I was quoted a price of $4900.00.
   / Powered rake #4
it beats to have to get off whenever you need to move the rake from one angle to another. leveling becomes a cake walk because you can move material around in many direction in the same passage.
this attachment is the dream for a manual york rake owner like me. one of these days we will get one.
   / Powered rake #5
I have rented one a couple of times and agree that they are very effective and versatile,If you can do it get it.
   / Powered rake
Do you still have to do hand raking before seeding. I want to start a one man yard finish business one of these days and want to use machinery to do the work instead of my tired old body.
   / Powered rake #7
after we use a rock hound we very seldom have to hand rake.
   / Powered rake #8
if you do not want to buy or rent a rock hound at first, as to keep your overhead down. do a good job at raking the area with a york rake type (non powered). pick up the rows of rocks with a coal or manure fork ... this way again you do not have to do too much hand raking.
good luck in your business start up
hans
   / Powered rake #9
I have a Harley pro 6 rake and I have just installed a carbide tipped roller on compared to replacing it with the stock bar roller and I am waiting for my new machine to come in to try it,in the meantime I have been using a friends Cat skid steer w/a harley rake,it is much different than using one on a three point hitch but it works extremely well.If you have the doe to get one it is well worth it,just the time saved in labor is worth it and the things you can do w/it are just about endless,from grading driveways to stripping sod,or just putting in an everyday lawn and once you get the hang of runnin' it the only hand work is to drag a grading rake over the caster wheel marks and you really don't need to do that,it just makes the finished product look that much better.
   / Powered rake
bubenberg:
Can you give me a link so I can see what a rock hound is?
2020 KUBOTA RTV...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
CATERPILLAR D6T...
