Power washer pump oil change.
   / Power washer pump oil change. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I thought to look at the sight glass on my pressure washer pump and it had enough but looked milky. Sure enough it was. It’s probably about 15 years old and I’m guessing I’ve changed it once at the most. The manual says every so many hours or every 3 months. I’m not going to change it every 3 months but I need to do it more often. It’s a Simpson power washer..
   / Power washer pump oil change. #2
Eww. That’s nasty. Maybe after changing it, run it for a half hour and change it again.
   / Power washer pump oil change. #5
Almost all of us has some piece of equipment that gets overlooked!
Who's perfect?
Good Luck!
   / Power washer pump oil change. #6
I change mine every year.
   / Power washer pump oil change. #7
I think I better check mine out, I’m way overdue to change it.
I changed it again, it still looked contaminated, maybe not as bad. Is there some kind of seal or gasket that might be bad that allows water into the oil side of the pump? I’ve never had one apart. It wasn’t overfilled when I changed it the first time.
   / Power washer pump oil change. #9
I change all of my pressure washers oil quarterly but they will run 8-10 hours a day, 5 days a week at times. Sound like you have some leaking seals or bad plunger. I would check into that. If you aren't running a bypass system on it, I would look into adding one. Heat is the killer on these machines so you need a constant flow of water even when OFF the trigger.
2006 Mack CV713 Granite Truck, VIN # 1M2AG11C36M039886 (A51572)
2006 Mack CV713...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
