Power washer pump freezes?
   / Power washer pump freezes? #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
Do those of you living in colder climates winterize your power washer pump? I got my PW out of the barn and used it for the first time last weekend. I can't help but feel frustrated though, that I could'nt use it all winter. My PW has a Comet brand pump on it and the manufacturer recommends that you fill the pump with antifreeze in the winter. They warn that a freeze-up in the pump will damge it and is not covered by warranty. So, I filled it with RV antifreeze and let it sit all winter when I really needed it to remove mud from the cars.
Any thoughts?
Jerry
   / Power washer pump freezes? #2
Seems like you could drag it out on a nice winter day (above freezing), use it and then re-winterize it. It probably doesn't take much anti-freeze to fill it, does it? BTW, I've learned from winterizing our camper that RV antifreeze will kill your grass so watch where you spray that thing /w3tcompact/icons/smile.gif
   / Power washer pump freezes? #3
I use mine all winter long. When I'm done using it I just store it in the heated barn. Never had a problem. If you have a shop or even a room in your house that you could store it in you will be fine.
I don't have a heated space that I can store it in. I would also be concerned about the fuel vapors. I have thought about wrapping the pump with heat tape. If you're not familiar with heat tape, its electrically heated cord that is used to keep pipes from freezing. I have a laundry tub in my attached garage and the faucet freezes up when I forget to shut it down and drain the pipes in the winter. Maybe I should put some heat tape there too. That way I can use my sink in the winter.
Hey, wait a minute, why am I talking all this 'winter talk', Its spring-time, right?
Jerry
   / Power washer pump freezes? #5
<font color=blue>Hey, wait a minute, why am I talking all this 'winter talk', Its spring-time, right?</font color=blue>
Sure its spring, time to start preparing for next winter... /w3tcompact/icons/wink.gif
   / Power washer pump freezes? #6
<font color=blue>time to start preparing for next winter</font color=blue>
over 20 years ago I did just that ... moved south!/w3tcompact/icons/cool.gif
mike
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2015 Hyundai Veloster Hatchback (A50324)
2015 Hyundai...
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
