Power-Tracs are not cheaper in my opinion
   / Power-Tracs are not cheaper in my opinion #181
Barryh said:
So Kent, I'm sure it's on this forum somewhere. What did you find your PT needed if anything, when you got it home and had a chance to really go over it? You seem to have had pretty good luck with your buy.
Nothing really. I just changed the engine oil and filter, air filter, hydraulic filter and went to work. Nothing was significantly wrong with it, and it had been pretty well maintained by PTRich.
I quickly discovered tire problems working in the woods behind my house, though, and had a series of flats before I loaded the tires and put Hydro-Seal sealant in them. Only problem with tires since then has been breaking off valve stems in the woods twice. I also changed the hydraulic fluid to 20W50 Amsoil after about 50 more hours (around the 300 hour point, as I recall).
Since then, I've had a cooling fan go out, replaced the battery (it was the original from 2000), and my friend cracked the weld on the rollover tube and had it re-welded. Other than routine engine oil changes and hydraulic filter changes, that's all I've done except work the heck out of it when I get the chance... :)
2024 FORD F250 SUPER DUTY BED (A57880)
2024 FORD F250...
2019 TAKEUCHI TL12V2 SKID STEER (A52707)
2019 TAKEUCHI...
2013 JLG SkyTrak 6042 6,000lb 4x4 Rough Terrain Telehandler (A55851)
2013 JLG SkyTrak...
2017 KENWORTH T800 TRI AXLE SLEEPER TRUCK (A57880)
2017 KENWORTH T800...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
GROUNDHOG ZH12G EXCAVATOR (A57192)
GROUNDHOG ZH12G...
