Power Trac stump cutter
/ Power Trac stump cutter #1
lstumper067
North Mississippi / Nash Ridge
Kubota BX2230/Ramrod mini skid loader/Carlton stump cutter
Is anyone using a stump cutter on their Power Trac, If so I would like to know more about it's preformance, any help would be appreaciated.
stumper067
/ Power Trac stump cutter #2
I have one for my 1430. It works ok, although the lack of shields will throw debris 50 feet in everydirection. We use it more to shear and prune roots rather than actual stump grinding. I would recommend a dedicated stump grinder if you are planning on using it a lot.
Bill
/ Power Trac stump cutter #3
II use the stump cutter with a 1445. It produces a cut about 1 and 1/4 inches wide. To remove a stump you have to move the PT constantly to grind it down. You can minimize some the debis by keeping the quick attach plate vertical. As Yardscaper said the stump cutter works well to cut roots in ground that you want to remove with a bucket. Just make a lot of minitrenches with the stump cutter to soften up the dirt and roots.
/ Power Trac stump cutter #4
I have one for my PT-1418, and I've used it to cut quite a few stumps. It's probably my least favorite attachment, to be honest. It will do the job, but it takes quite a bit of time. It slings all the debris back at the operator and the tractor, which I really don't like.
That said, it may not be as fast as I'd expect, but it's a heckuva lot faster than cutting a stump by hand. It's also quite good for cutting mini-trenches, as someone else had mentioned. If you want to bury 12V landscape lighting wire or sprinkler hose, etc., it'll cut a trench in dirt in a hurry.
I haven't tried it, but I'll bet this thing would cut a slice in asphalt as well. Might even cut a groove in concrete (but I'll bet you'd have to change the blade after that!)
I got mine with my old used machine, so in my humble opinion, a small stump grinder is better than no stump grinder.
HTH,
Dave
/ Power Trac stump cutter #5
"" It slings all the debris back at the operator and the tractor, which I really don't like. ""
Check out my latest post #443306 at PT-425 PROS & cons?? !!
/ Power Trac stump cutter #6
Hey! Thanks 14...Power-trac told me that the stump grinder motor wasn't reversible, or I would have already turned this sucker around! I guess they were incorrect...
Thx,
Dave
/ Power Trac stump cutter #7
Only if you have the same motor as fourteen /forums/images/graemlins/wink.gif
anybody know if the new stump cutters by Power Trac have replacable teeth?
stumper
/ Power Trac stump cutter #9
Don't know about the new ones, but I doubt it. On my old one, the blade itself is replaceable.
HTH,
Dave
/ Power Trac stump cutter #10
"" Power-trac told me that the stump grinder motor wasn't reversible ""
I checked with 2 large hydraulic distributors who stated that the White Hydraulics Roller Stator Motor is 100% reversible.
I do not know if this is true for your motor. /forums/images/graemlins/confused.gif
However, I took the word of these hydraulic experts, and my Stump Grinder runs great!!
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Power Trac stump cutter #11
"" replacable teeth? ""
I was told by Power Trac that they would weld on new teeth, or sell me a new blade, but based upon the current level of wear, I expect that that will be in the far distant future!
The carbide teeth are very large, hard, and strong. When I was working in nuclear power plants, we drilled hundreds of large holes in high strength concrete walls using carbide bits. Occasionally the carbide would chip upon hitting rebar at an angle, but otherwise they would seldom need to be replaced!
2006 Bentley Continental Passenger Car, VIN # SCBBR53W76C033311 (A65563)
2006 Bentley...
Frontier 4' 3Pt Mower (A66408)
Frontier 4' 3Pt...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
3Pt Backhoe (A66285)
2012 Ford F-550 Flatbed Truck, VIN # 1FDUF5GY6CEB41814 (A65563)
2012 Ford F-550...
(2) Lexion 7564961 Sieves and (3) 7574411 Grates (A65640)
(2) Lexion 7564961...
