Power Trac Replacement Engines Suggestions!?!?
   / Power Trac Replacement Engines Suggestions!?!? #31
He hasn't posted since April 2003, so dont expect a quick reply. ;)
   / Power Trac Replacement Engines Suggestions!?!? #32
scarg said:
Cool- A few years later what is your current status with the 27 HP Kohler? Can we see some pictures now? The crank on my 422 from PT looked like it was hacked off with a chainsaw. I don't think anyone was concerned with balance when they cut mine off. I have a current thread as my 3 year old 422 with 450 hours on it just siezed last week. Any comments would be great.
BR,
Steve
Steve, let me ask you this again, Did you notice any vibrations with your Robin during normal operation?? Thanks Barry :eek:
   / Power Trac Replacement Engines Suggestions!?!? #33
Barry,
No - no vibrations and all seemed well.
Steve
   / Power Trac Replacement Engines Suggestions!?!? #34
scarg said:
Barry,
Steve
   / Power Trac Replacement Engines Suggestions!?!? #35
I read this article about a new Deutz turbocharged engine . I thought some of you might be interested.
Deutz has expanded its 1011F series of engines to include the new BF3M1011F, an oil-cooled, turbocharged three-cylinder diesel. The new engine has an output range of 36 to 62 hp, depending on the configuration, and is designed to provide the power of a larger engine in a smaller envelope. The 2.2 L engine has a bore and stroke of 3.6 x 4.4 in. and a compression ratio of 17.5:1. Maximum torque output is 135 ft.lb. at 1800 rpm.
   / Power Trac Replacement Engines Suggestions!?!? #36
One of those would git my 1430 up the hill. JJ, was that a recent article? I thought I read that Deutz replaced the 1011F series with 2011F.
   / Power Trac Replacement Engines Suggestions!?!? #37
I do think of turbocharging my PT, but I have to wonder what heat issues would arise... Also, could the Deutz engine still be rated at 45 degrees with a Turbo....
Carl
   / Power Trac Replacement Engines Suggestions!?!? #38
You are right, that is old news. Sorry.
   / Power Trac Replacement Engines Suggestions!?!? #39
The rebuilt one that was for sale on E-bay recently was I believe 79 HP. Pistons were cooled by an oil spray. So far, I have not been engine limited. How about you, Carl?
I have been limited by lift capacity many times recently. I have had 3 tractors with different lift capacities: 800 lbs, 2000 lbs, and now 1200 lbs. It hurts to go "backwards". 3000 lbs would be nice. Work sold an outdoor forklift that only had a few hundred hours on it but was 30 years old. A friend heard about it and turned it down and did not think to ask me. It sold for $600. If he wasn't such a good friend he might be an ex-friend!!!:D
Ken
   / Power Trac Replacement Engines Suggestions!?!? #40
On my steepest incline that I normally traverse (25 degrees) I bog a bit at the top (300 feet long slope). As any normal person I want more power. I totally agree with Ken, the engine is enough, but the front end lift is really a shame. As my piston rod on my tilt has a slight bend in it, I plan to order all new cylinders for the front, upgrading them by a quarter or half inch...
Carl
2006 KENWORTH T800 CRANE/DUMP BED TRUCK (A57192)
2006 KENWORTH T800...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
RoGator RG1100C (A55315)
RoGator RG1100C...
2023 Kubota L2502DT (A53317)
2023 Kubota...
2008 Bobcat T190 Compact Track Loader (A57024)
2008 Bobcat T190...
