Power Trac PT-422 and attachments for sale
   / Power Trac PT-422 and attachments for sale #41
</font><font color="blue" class="small">( MOWER DECK CLEANING
There is a solution that you might try. A lot if the commercial people, mount a water jet just above the blade tips, one jet per blade. All the jets are connected on the top to a quick connect water hose attachment. Hook up the hose, turn on the water, and activate the blades. )</font>
Well now that's a novel solution. I like it. By "water jets" what do you mean exactly. What am I looking for and where can I get 'em?
   / Power Trac PT-422 and attachments for sale #42
The cheap way to go would be to use sprinkler head nozzles, but they are all plastic. The ag industry uses plastic and steel nozzles on the spray booms. Pressure washer nozzles might work also.
It would be best to clean just after mowing, before all the gunk hardens.
   / Power Trac PT-422 and attachments for sale #43
well the 60'' mower arrived and i hooked it up at 5.45 and was done with all the grass by 7.30 and thats with two neighbors wanting to know just what this thing was lol well im happy about the mower it cut the high grass ok but it should do better when i use it weekly i suppose i do have aquestion does anyone else have the 60'' mower and does it make alot of noise while its running at times it gets quieter but seems to make noise again not sure if it is a normal thing or not /forums/images/graemlins/confused.gif
   / Power Trac PT-422 and attachments for sale #44
Should have a high pitched whine. Be sure you are at full throttle. Also use a high temp grease and hit the blade hubs for each mowing.
PJ
   / Power Trac PT-422 and attachments for sale #45
I have the 60 and I always use it at the highest throttle setting. I also always wear hearing protection. It is very, very loud. /forums/images/graemlins/wink.gif
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
2019 Deere 35G (A53317)
2019 Deere 35G...
Kubota BX25D (A53317)
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
RoGator RG1100C (A55315)
RoGator RG1100C...
