Power Trac 1850 Wheels seals
   / Power Trac 1850 Wheels seals #1
markkas
Mercer Pa
power trac 1850
Anyone know where I can get wheel motor seals other than power trac?
   / Power Trac 1850 Wheels seals #2
If you can identify the specific brand and model number of the wheelmotors, virtually any hydraulic supply/repair shop can get them. The challenge is figuring out what you have. Tazewell doesn't make it easy, but there may be a tag or label on the motors. You may have to unbolt the motors from their mounting boxes to see if it is on the back side....
   / Power Trac 1850 Wheels seals #3
If you have precise measure instruments, you can measure and take results to a hyd shop to look up what you have and need and get off the shelf parts or order the correct seal.
You might also take the old seal so they can determine the seal material.
You really can't measure old seals as they swell or become brittle, or shrink, etc.
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
New/Unused 70in Quick Attach Seeder (A51573)
New/Unused 70in...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
