power steering
   / power steering #1
augercreek
duluth mn
f12 farmall100,h
Have any of you converted a car power steering unit to use on a full sized tractor?I'm making a custom tractor out of a f12 farmall with a chevy 153 4cyl. engine.I want to change the position of the steering wheel from verticle to about 45* and have a dash board to match that angle.Power steering units for tractors are way too expensive so I'm looking for options.
   / power steering #2
rack and pinion or recirculation ball style? ... either one can have a universal joint to swivel the steering wheel ... or get a tilt steering column from a wrecker .....
small cars use the r&p ... most trucks still unit the recirc ball type ...
   / power steering
I'm not sure which type to use as the steering on the f12 is worm gear.R&P seems probably the way to go.I also have thought about a hyd.pump & motor closed system.Steering wheel mounted to the pump shaft with the motor mounted to the worm gear shaft.Easy to run hyd lines.More to think on!
   / power steering #4
Have a gander at this.
Cheap electric power steering and or rotary servo
   / power steering
Gosh I never knew about such a unit! Thanks alot!
Dion 1224 XC Silage Chopper (A50515)
Dion 1224 XC...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
John Deere 7520 (A50120)
John Deere 7520...
24in Tractor Backhoe Bucket BT4555 (A52748)
24in Tractor...
Wolverine Mini Skid Grapple Bucket (A50514)
Wolverine Mini...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
