power steering
/ power steering #1
ted hayes
kaufman tx
mihindra 600
Mihindra 6000 is leaking power steering fluid around steering wheel! Has anyone had this problem, and what does it take to fix it? Any help would be much appreciated.
/ power steering #2
Ted, around the wheel at the top of the steering column or at the shaft in the engine compartment?
/ power steering
Around the top at steering wheel
/ power steering #4
Ted,
There is a steering valve under the column......look carefully, you'll probably see it with four hoses going into it....
Not sure of your exact model but these steering valves are common and can be resealed
Pix..??
/ power steering #5
The steering valve must be spraying directly up the shaft, and at a pretty good clip for it to be leaking at the steering column above the dash.
/ power steering
Thanks, I did pull out gauges and saw no leaks down low, looks like oil is only coming directly under steering wheel.
/ power steering #7
I would expect you will only see it when it is under pressure as you turn. Can you turn it with the gauges off?
/ power steering
Yes should be no problem,thanks I'll give that a try.
/ power steering #9
Ted, I think power steering fluid is corrosive so keep a rag handy and clean up well. If it is dot 4 I beleive it is okay, if Dot 3 or older style it is.
/ power steering #10
Dot 3 & 4 brake fliud??
Steering systems use hyd oil from the main reservoir......not corrosive
/ power steering #11
Ted, Steering valve shaft seal is leaking, kit is pretty inexpensive but its quite a job getting the valve out and in. BTW steering should be using ATF dextron fluid.
Dave
/ power steering #12
Yep, checked my manual, thanks for the correction.
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
211299 (A62131)
211299 (A62131)
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Kubota L295-DT Loader Tractor (A66285)
Kubota L295-DT...
