Power steering question 4400
   / Power steering question 4400 #1
Tritonman
Can anyone tell me what the source of oil is for the power steering on a 4400. My 4400 only has good power steering when the rpms are cranked up to 3/4 throttle. Would you say it is something with they cylinder or filter? Thanks
   / Power steering question 4400 #2
The oils comes from the main hydraulic sump. There is two hydraulic pumps on the tractor, one is for the implements (3PH, FEL, ect,) and the other is dedicated to the steering. The only filter is the main one on the transmission.
It's possible that the pump is heading south, or there is a kinked hose to the cylinder, or the steering valve is going bad. You will probably need the service manual to see how to check the flow and pressure of the pump.
Thank you for the info.
10 GALLON SANDBLASTER (A54757)
10 GALLON...
14ft Deer Gate (A55758)
14ft Deer Gate...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
CATERPILLAR PC306B SKID STEER HYD COLD PLANER (A54756)
CATERPILLAR PC306B...
