Power steering Pump for Ford 821 Powermaster?
/ Power steering Pump for Ford 821 Powermaster? #1
jon1996
Bronze Member
I have a Powermaster Backhoe, I am gathering parts for the restoration this winter and you all have been a big help on the electrical side, I have everything for that, Now I need to find a Power steering pump that will fit on it, I heard that one off a 1976 chevy something would work, but wanted to be sure first
thanks,
/ Power steering Pump for Ford 821 Powermaster? #2
do you have all the rest of the ps system sans the pump.. or are you pieceing it together? if piecing.. I suggest getting a complete setup from a donor tractor.
soundguy
The tractor has power steering on it, but it has a toyota pump that barley works, But the steering colum and all the lines and rams are there from the factory, I just need a new pump and resovoir to mount on the right side of the engine, Some goon put it on the left side of the engine hence removing the alternator, thats why I am going to redo the whole thing
/ Power steering Pump for Ford 821 Powermaster? #4
do you have the bracket and the cooling top hose bracket?
soundguy
Im making all my PS Pump and Alt brackets, I just need a pump to fit first, And I do have the threaded ear on the radiator Hose Bracket,
Or Better yet Would it be possible to tie it into my Hydraulics on the Front Pump?
/ Power steering Pump for Ford 821 Powermaster? #6
Very possible to tie in to loader. You would need to fix a priority flow control valve to give the correct volume first then a step down in pressure to about 1000-1300 (at a guess) psi. I also am guesstimating the volume at about 3-4 gpm. Like everything fabbed up, it's smart to start on the low side of both pressure and volume then sneak up on it to get the lowest acceptable flow and pressure.
/ Power steering Pump for Ford 821 Powermaster? #7
yep.. buddy of mine has done that using the front pump.
I'd look at jackson power steering, they make power steering conversions for many tractors including fords.. they have kits to work with a priority valve ( as mentioned ) vs using another ps pump.
soundguy
2016 Ford F-150 Ext. Cab Pickup Truck (A61573)
2016 Ford F-150...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
