Power steering needed for a 3000
   / Power steering needed for a 3000 #1
Laneman
Anyone find a low cost source for power steering kits that will fit a diesel 3000 with loader? Used is ok, just on a tight budget.
   / Power steering needed for a 3000 #2
budget? like 1000$ or 1500$ or? lower.
if lower.. then imight try to strip the all involved parts from a junker..
soudnguy
   / Power steering needed for a 3000 #3
you wont find one for less than 1500 even from a salvage yard thaat will fit on there with a loader
   / Power steering needed for a 3000 #4
I have an early 3000 with the external cylinders. The pump is gear driven off the crank timing gear. It would be a big deal to convert to this type system. Mine is completely out of action with bad cylinders and a pump that won't hold a shaft seal. I'm not sure that $1,500 would get my P/S back in shape again. All the parts are heck for expen$ive.
A question I have is: was the power steering on the later 3000's in the steering gear box like a later model car as opposed to the external cylinders? If so, you would be much better served changing to this system.
   / Power steering needed for a 3000 #5
no all 3000's have external cylinders u have to get to a 4000 series tractor to have a orbit motor steering system
   / Power steering needed for a 3000 #7
I was just looking on ebay for P/S parts and found two entire conversion kits for 3000's including pump, linkage, cylinders, hoses, etal. One of them was under $400 Buy it Now price.
Go to ebay and search: Ford 3000 Power Steering
$400 is a good price for the entire steering kit, but still a little high for my limited budget. The design from the Kubota forum runs around $250 for the parts and uses power from the 3PH system. It needs around 1.5 GPM to run. The spec for a 3000 says the system has 5 GPM available so I think I can borrow 1.5 without a problem.
   / Power steering needed for a 3000 #9
I've had my factory p/s equipped Ford 3000 for almost 24 years. The p/s has been a source of headaches and expense for all that time. To put it in top shape with replacement parts would probably be a $1,500 proposition. That said, less than $400 seemed like a steal of a bargain to me.
   / Power steering needed for a 3000 #10
Search for member BOSTONRATS, Power steering in 90 minutes, seems a neat solution but I imagine it costs more than $400.
1779 (A51248)
1779 (A51248)
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2012 Mitsubishi Outlander Sport AWD SUV (A51694)
2012 Mitsubishi...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
