nailerguy
Hey Dennoace, I guess we will have to agree to disagree on this one. However if you will reread my earlier post, I stated that any trapped air in the system SHOULD be out now that the tractor has been used some, and that barring trapped air, bad pump, relief valve etc. the only thing that changed was the oil viscosity.
You state that you have worked on hydraulic systems 10 times this size, well so have I and I have had experiences like this and found ways to compensate for them and aleviate the problem.
Maybe when you test drive that new tractor, you should ask the dealer to change the power steering oil to the low viscosity fluid first and if there is no problem, great but if there is???? What then??
Perhaps John Deere knows exactly why the tractor is doing this but does not want to admit it, perhaps it is as they say and they don't have a clue unless the larger tires on the back have actually caused the problem, ( I personally doubt this had any affect on the steering). Back in the late 1970's we use to put the biggest tires we could find on the back and "littles" on the front of our cars, because we thought it looked cool, /forums/images/graemlins/tongue.gif I don't remember anyone having power steering problems from doing this, in fact, you only had problems when you started installing 12" lift kits and monster mudders on your pickup truck! /forums/images/graemlins/grin.gif
If Jclark had put larger tires on the front of the tractor, then you would have increased steering effort to turn the larger tire with the larger contact patch. He put the larger tires on the back! it should have had no effect on the steering at all, and in fact it did not until he changed the fluid at 62 hours.
Anyway, we all want this problem solved for JclarkAnd we are all entitled to our opinions which are usually based on our experience. I'll tell you what, I'll respect your position if you'll respect mine. /forums/images/graemlins/cool.gif
Nailerguy
Nailerguy
